jbeuckm
Audio files: 9
Posted: Thu Aug 27, 2015 5:46 pm Post subject:
808 Handclap (almost there) |
The simple noise envelope is working but the clackity clack is not happening. Help me debug!
I substituted the BA6110 but did not build the current mirror as suggested here: http://www.firstpr.com.au/rwi/dfish/TT-303/click-fix/
Could that be the problem?
Eagle files are here:
https://github.com/jbeuckm/808-Handclap
Description: |
Filesize: |
94.58 KB |
Viewed: |
1208 Time(s) |
Description: |
 Download (listen) |
Filename: |
bad_808_clap.mp3 |
Filesize: |
44.93 KB |
Downloaded: |
1130 Time(s) |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Fri Sep 04, 2015 4:23 am Post subject:
Started to have a look at this one in Eagle, I used your schematic, but started to reroute to have all resistors lying down, a bit more compact, and adjustments for parts which I have in my bin.
I'll try to spot mistakes before committing this to an iTEAD order
Did you see these?
Yocto build tips
E-licktronic (Yocto) errata |
jbeuckm
Audio files: 9
Posted: Fri Sep 04, 2015 7:14 am Post subject:
Thanks! I'm pretty excited to get home and flip C144... There are plenty of things to measure and try here. |
jbeuckm
Audio files: 9
Posted: Tue Apr 26, 2016 9:03 am Post subject:
@LFLab Any luck? I have restarted this layout from the Yocto eagle file. I probably had a bad connection or wrong value on my first version. Also, I am moving to 2N390x transistors this time to avoid any pinout variations. I'm doing the reverb mod too. |
LFLab
Posted: Tue Apr 26, 2016 9:17 am Post subject:
I actually did a layout....for the 909 clap
Nothing going on on my end on the 808 clap. |
jbeuckm
Audio files: 9
Posted: Tue Apr 26, 2016 9:36 am Post subject:
Very similar circuit. Which OTA did you use? |
LFLab
Posted: Tue Apr 26, 2016 11:36 am Post subject:
CA3080, usually I'd replace this with 13700, but for the life of me I couldn't figure out what to do with the other section, and I do have quite a few of them around.
It only exists in Eagle now though I used hexinverters neinohnein schematic, so that should be good.
I have some grief with the Yusynth Quadrature LFO to deal first  |
jbeuckm
Audio files: 9
Posted: Tue Apr 26, 2016 2:45 pm Post subject:
Oh that's easy - use the other half of your 13700 to CV the reverb level  |
jbeuckm
Audio files: 9
Posted: Wed Apr 27, 2016 8:55 pm Post subject:
Woohoo - verified! I had to change C140 to 27n to get separated hits (2n7 in the service manual). This has reverb level on a 16mm edge pot. Requires separate noise source.
https://github.com/jbeuckm/808-Handclap/releases/tag/v0.1
Description: |
Filesize: |
51.25 KB |
Viewed: |
887 Time(s) |
Description: |
 Download (listen) |
Filename: |
808_clap.mp3 |
Filesize: |
538.81 KB |
Downloaded: |
1047 Time(s) |
LFLab
Posted: Thu Apr 28, 2016 3:28 am Post subject:
Very nice!  |
ADMST
Posted: Mon Dec 12, 2016 12:38 am Post subject:
Man, your work is inspiring! Will this design run at +/- 15v ?? |
jbeuckm
Audio files: 9
Posted: Tue Dec 13, 2016 8:08 am Post subject:
Yes. The original was 15v afaik. I think I actually used a +-15V power supply on mine through a euro connector. |
ADMST
Posted: Tue Dec 13, 2016 11:18 am Post subject:
Amazing. Thank you! |
artilect99
Posted: Wed May 29, 2019 4:07 pm Post subject:
Sorry for the noob question, but I've never had a PCB fabbed before. How exactly does one go about getting a PCB made from files such as these? Do I need eagle in order to convert them to gerber files? |
lilpaula87
Posted: Mon Sep 12, 2022 3:51 am Post subject:
Wow I’m really interested in this project but I already have a midi to cv and a cv to trigger module. There’s a way to slightly modify this pcb to add an external input for trigger and accent? |
