G2 software installation issues
Page 1 of 1 [4 Posts]
Vader77
PostPosted: Wed May 11, 2016 1:03 am    Post subject: G2 software installation issues Reply with quote  Mark this post and the followings unread
Finally got a G2 however I'm trying to get the USB driver to load on an old Gobook with XP (32 bit).
The latest USB drier seems to get stuck in some installation freeze and when I try to install the pre Vista version it says i need to insert the Clavia CD which I don't have. Has anyone experienced this? Do I need to burn the pre vista usb driver on a CDr?
The G2 is on v1.24.
thanks
Electromagnetic Wave
G2 patch files: 38
PostPosted: Fri May 13, 2016 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is 'the pre Vista' ? windows vista ? because you speak about xp before. Im confuse a bit.
Do you have an option to select the folder manualy where the driver is ?
brunov
PostPosted: Sat May 14, 2016 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
If the computer gets stuck trying to install the clavia driver, you can try installing in windows safety mode.
My old OS NMG2 editor: http://sourceforge.net/projects/nmg2editor/?source=directory
My new G2 editor FMX: http://www.bverhue.nl/g2dev/?page_id=17
Source code: https://github.com/BVerhue/nord_g2_editor
Vader77
PostPosted: Mon May 16, 2016 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers guys turns out using the USB v3.03 driver from the Wave downloads works a treat!
