 Forum index » Instruments and Equipment » Waldorf
Microwave individual out weirdness
Page 1 of 1 [4 Posts]
Regebro
PostPosted: Sat Sep 05, 2015 2:21 pm    Post subject: Microwave individual out weirdness Reply with quote  Mark this post and the followings unread
I was highly confused today, when sound from my Waldorf Microwave was highly spurious. With some sounds it was consistent, I got a sound every 4th or every 8th note.
After some head-scratching I realized I had patched myself in on the individual outs, not the main outs: Problem solved.
But still, what's up with that? Any explanation for that behavior?
rEsrEs
PostPosted: Tue Oct 20, 2015 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
iirc the mW1 will cycle through the individual outs in Single mode, using a Multi patch properly set up will solve this.
Regebro
PostPosted: Wed Aug 24, 2016 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, I guess this is so you realize that there is a sound being made if you are on the individual out, and don't start looking for broken cables.
rEsrEs
PostPosted: Wed Aug 24, 2016 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's all about the voice allocation.
in Single mode, it's allocating 8 voices of polyphony to 4 individual outputs. so, you 'should' hear the same note every 4th/5th time. we 'usually' play nonsense on the keyboard when testing, so 'usually' the one note we are trying to hear gets re-allocated to a different output and we are left scratching our heads, thinking our precious microWaves are broken.
in Multi mode you have almost total control over the outputs, not forgetting Unison. so it makes no sense to use the individual outputs in Single mode.
