Yves' archive, "Synthesizer schematics" by Thierry Rochebois
Page 1 of 2 [44 Posts]
alanwilder81
PostPosted: Sat Sep 03, 2016 2:49 pm    Post subject: Yves' archive, "Synthesizer schematics" by Thierry Rochebois Reply with quote  Mark this post and the followings unread
hello everyone,
has anybody attempted to build the "keyboard interface CV-GATE-TRIGGER" circuit?
it looks really nice and low components count.
It is in Yves's archive, on the last article on the page bottom, called "synthesizer schematics" by Thierry Rochebois
http://yusynth.net/index_en.php?&arg=1
any comment or help would be appreciated
yusynth
PostPosted: Tue Sep 06, 2016 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
No I haven't built it, but it was a student project that was successfully completed and the schematics published by Thierry were all tested therefore I guess you may be pretty confident in these. I see no flaw in them.
Yves
alanwilder81
PostPosted: Tue Sep 06, 2016 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
good morning Mr. Yves,
greetings from Italy.
I'd like to show you my greatest appreciation for your amazing works and your efforts in sharing accurate schematics and knowledge with all of us.
That enabled me to build some of your modules,in particular the Steiner filter and the saw core VCO that proved excellent.
i am now building the "simple VCA" and the "classic ADSR", in order to make a very simple architecture synth.
I can now confidently build the keyboard circuit as soon as i get the missing components, and i will let you know about the developements.
Again, thanks for your time, and i hope i can get some of your advices when getting the modules together. Very Happy
alanwilder81
PostPosted: Sat Sep 10, 2016 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Yves,
I built the VCA module, listed on "my old synths" circuit collection, from US1.
here's the link
http://yusynth.net/gear/US1/images/VCA-US1.gif
can i use it as a simple VCA for my mono synth project? How do i go about setting the trimmers properly?
I'd like to know how it compares to the more advanced "simple VCA", which i can't build, as i haven't got a dual trace scope Confused Confused
thanks in advance ! Razz
gdavis
PostPosted: Sun Sep 18, 2016 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
alanwilder81 wrote:
hi Yves,
here's the link
The US1 circuit only works as an AC (audio) VCA. The "simple VCA" can work as AC or DC (for control voltages). It adds a trimmer to null the DC offset (not important for AC) and some control knobs to give it more flexibility. If you just want a basic VCA for the audio output of your synth, US1 should be fine.
Setting the trimmers for the US1 is actually very similar to trimming the "simple VCA" and using a dual trace scope would be ideal. The idea is to match the output signal to the input signal. However, in a pinch you can do it with a single trace scope, just measure the input waveform then adjust the trimmers while observing the output until it's the same as the input. If you don't have a scope, just set the balance trimmer in the middle and the gain trimmer by ear. Won't be perfect but if it sounds OK then it's OK.
alanwilder81
PostPosted: Sun Sep 18, 2016 4:44 am    Post subject: Reply with quote  Mark this post and the followings unread
hey gdavis,
thanks for replying Smile Smile
it's the first time i've really ventured on building a VCA,so please don mind some noob questions ! Embarassed
can you shed some light on the basic VCA knobs and parameters ? am bit confuse as to what each knob does what. You know.
As far as what i can grasp, a VCA input can be both for AC and DC,respectively for processing audio stuff and CV signals. Right?
Now,i am only interested in running my humble VCO through the VCA to get a volume envelope.
Then, is the DC offset knob irrelevant to do my job?
Else,i keep seeing the BIAS knobs. What are they? And the gain knob?
When i built the US1 VCA i noticed that the volume stayed always ON, there was no way to silence it.
Is that how it's supposed to work?
excuse my many questions.trouble is ,despite much researching they have remained unanswered for most part.
thanks in advance !! Very Happy Very Happy
gdavis
PostPosted: Sun Sep 18, 2016 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
alanwilder81 wrote:
hey gdavis,
Input Level #1: Controls the level of the signal coming into input 1. Kind of like a volume control for the input. Can be useful if the signal coming in is too strong and causing the VCA to distort for example.
Gain: Kinda of like a manual control for the VCA, lets you adjust the output volume without a control input or shift the overall effect of the control input louder or quieter.
Control Level #1: Controls the amount of effect from the signal on control input 1. For example, if you have a 0-10V CV coming in, the knob can reduce the range so that the VCA only opens and closes a little bit instead of full volume.
Gain and Control Level together give you flexibility that can be very useful when using the VCA with CV signals, but aren't as useful for audio IMO. Much easier to understand when you can actually try them out.
In general that is correct. Be aware that for the "simple VCA", you need to remove C3 and C4 in order for it to work as a DC VCA. The US1 VCA lacks the offset trimmer making it less desirable for CV even if the input cap were removed. You can't use coupling caps with DC because the cap blocks DC and only passes signals above a certain frequency.
That is correct. Whatever audio input you connect the output of the VCA to is going to have a coupling cap that will remove any DC offset. You can't hear DC offset, it's only a problem with audio if it's so large that the signal clips, but that's why the coupling caps are there, to prevent that from happening. For CV's, especially pitch CV, small DC offsets can be very noticeable which is why you have a trimmer for it in DC VCA's.
Not sure what you're referring to as bias. Gain is described above, basically a manual control for opening and closing the VCA.
No, it should be silent when the CV input is 0V. The 22k trimmer needs to be adjusted so it's just silent. Then, increasing the CV input up to 10V should cause the VCA to open up proportionally.
No problem, hope that helped. Like I said, it's difficult to understand just reading about it. Really helps if you have a working synth to play with to understand what this stuff does. You might want to look for a free VST pluggin or something to try out and get a better understanding of how it should work.
alanwilder81
PostPosted: Sun Sep 18, 2016 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello gdavis,
many thanks for your incredibly articulate response. I'll take a deeper look later.That sheds a light on the VCA working principles Smile Smile great stuff.
I have played VST synths forever. I've learned the crap out subtractive synthesis right on those fake sounding emulation Wink Wink
As bad,as cold, as sterile VST's might sound, they gave me the opportunity to get a solid gasp of the audio path,at least.
Also ,i recently had the chance to play some real analog baby, and i was hooked. I decided it was time to go DIY all the way because it's the real sound that i am after.
So i am humbly trying to get grasp with basic VCO-VCF-VCA architecture mono synths.Very rewarding experience ! Razz
alanwilder81
PostPosted: Sun Sep 18, 2016 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
to gdavis,
should you need me to provide you with the schematics ive been working on,just dont hesitate to ask . I'll keep you posted with the next VCA developments. Again, thanks for the great infos and willingness ! Very Happy
alanwilder81
PostPosted: Tue Sep 20, 2016 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
hey Gdavis,
there's some great news Smile
i finally unraveled the VCA mistery,after making the US1 VCA and another one from EFM website by fonitronik.
The knobs are starting to make sense now, i manage to modulate the VCA by using the US1 AR generator.
Plus, i found a nice VCA ,very similar to Yusynth one,just a semplified version of the "simple VCA" that is in turn carbon copy of the US1 vca i built.
here's the schematics. It works,for whoever would be interested in it
http://kassu2000.blogspot.it/2015/10/vca.html Cool Cool
Cfish
PostPosted: Wed Sep 21, 2016 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The simplest example of this type of VCA I have ever found is the early PAIA VCA schematics. Sorry I looked for a few and couldn't find a link to it, but I know it's on line.
Glad to hear your making progress alanwilder81
alanwilder81
PostPosted: Tue Oct 25, 2016 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hello folks,
i am about to build the following keyboard CV GATE TRIGGER circuit that calls for a CD 4066 for the sample and hold section.
I recently got a bunch of CD 4016 ,i'd like to know if i can use it in place of the CD 4066 the circuit specifies. thanks folks !
 Filesize:  40.26 KB
 Viewed:  610 Time(s)
yusynth
PostPosted: Tue Oct 25, 2016 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes you can
Yves
Cfish
PostPosted: Thu Oct 27, 2016 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi alanwildr81
I have had this in my list of circuits to try since you posted it.
Would love to hear how it turns out for you. Looks like it should work great.
Wish I had seen the schematic a couple of years ago, however if I had, I might not have learned what I learned trying to build one I could understand.
alanwilder81
PostPosted: Fri Oct 28, 2016 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks very much Yves !
another question.
on the far left of the schematics,I see three outputs from the keyboard circuit called, from top to bottom, "noir", "blanc" ,"gris" .
They are connected to the circuit by the means of "dotted lines". Are those lines to be considered as regular cables and connections?
is there any particular reason for them not to be drawn as the rest of the circuit connectionss?
thanks !
alanwilder81
PostPosted: Fri Oct 28, 2016 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
to Cfish
I am glad you found inspiration from that schematic.i am just about to breadboard it.
yusynth
PostPosted: Sat Oct 29, 2016 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
another question.
thanks !
Yes they are connected. I suppose the dotted lines symbolise a ribbon cable with connectors on each side that interconnect the circuit board to the keybed board.
Yves
indigoid
PostPosted: Fri Nov 04, 2016 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
so I built myself a US-1 VCA also. My system is Eurorack, so +/-12V. I used TL072 and 2n3904 since that's what I had at hand, and as people often say 2n3904s are usually quite well matched for Vbe if they're from the same strip of paper tape, I didn't bother matching them.
When feeding it relatively-fast-but-not-audio-rate signals the top half [only] of the output wave is notably rounded off, as if it had been slewed.
Transistors not sufficiently matched?
I will keep tinkering with it.
yusynth
PostPosted: Fri Nov 04, 2016 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes probably
Yves
alanwilder81
PostPosted: Tue Nov 08, 2016 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Yves,now it makes more sense !
alanwilder81
PostPosted: Wed Nov 16, 2016 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello Yves,
i finally managed to build the keyboard circuit published by Thierry Rochebois.
It looks it works, i am immensely happy with that.
I would like to thank you for this and share this success, my synth now is complete
yusynth
PostPosted: Thu Nov 17, 2016 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent
Yves
alanwilder81
PostPosted: Fri Nov 18, 2016 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Yves. another question.
at the moment i am using an extra -10 V power supply cable connected to the ""echelle 1 V octave"" trimmer. it works but it's only temporary.
What would it be a better and definitive solution to raise the voltage from -12 to -10 in that section?
many thanks!
 Filesize:  46.94 KB
 Viewed:  401 Time(s)
yusynth
PostPosted: Fri Nov 18, 2016 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Or you can use a resistor, a 10V zener and a capacitor to create the 10V reference
Yves
alanwilder81
PostPosted: Fri Nov 18, 2016 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Yves !
