LDR VCA type thing
Page 1 of 1 [10 Posts]
mike page
PostPosted: Thu Feb 16, 2017 4:08 am    Post subject: LDR VCA type thing Reply with quote  Mark this post and the followings unread
Trying to get this little fella working but no joy. The left hand side could be any oscillator but I thought I'd include the one im using in case the resistance of the input is a factor.
(the left hand side works fine putting out a nice triangle 8v p-p, And the led is flashing and is coupled in the dark with the LDR)
Just connecting the oscillator to the lm324 seems to kill the signal.
I thought I felt confident about op amps as buffers but it seems im missing something!
Any thoughts?
PostPosted: Thu Feb 16, 2017 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
First of all: start measuring the resistance of the LDR when the LED is off, and when the LED is fully lit.
Read some more HERE
mike page
PostPosted: Thu Feb 16, 2017 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Read some more HERE
The LDR is a low value one (5516) and it swings from around 200k to a few hundred ohms.
PostPosted: Thu Feb 16, 2017 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have measured these resistances "in vivo" then is should work..
PostPosted: Thu Feb 16, 2017 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you happen to have a TL074 or a similar J-FET opamp laying around to
test with ? I think it should work with a LM324 but it being a single supply
opamp might mean there is some internal biasing that messes things up.
mike page
PostPosted: Thu Feb 16, 2017 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I checked my wiring and had a silly short. It works! And sounds good. Thanks for your replies all the same.
mike page
PostPosted: Thu Feb 16, 2017 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
out of interest... if i rearrange the LDR voltage divider as in the diagram I would get the opposite response. Right?
mike page
PostPosted: Thu Feb 16, 2017 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
oh and apologies if this is in the wrong bit of this forum! (I guess its not strictly lunetta chat)
PostPosted: Thu Feb 16, 2017 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
good to hear it works and yes that circuit should have the opposite responce.
There is something to say about it not being linear but generally speaking
more light results in a lower level.
As for it not being strictly lunetta, those kind of simple circuits do go very well
with lunettas so its fine Very Happy
StasV
PostPosted: Fri Jul 21, 2017 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Mike Very Happy
I was reading through the forum, got fed up with voyeuring and decided to finally create an account and start giving the ideas back to the community Smile
As to designing "a proper" LDR/LED optical VCA combo - you could use a NPN inverter like http://dlb.sa.edu.au/rehsmoodle/file.php/282/kpsec.freeuk.com/trinvert.gif to invert the VC that goes to the LED. If I'm not mistaken the upper part of the attached schematic (by Thesquarewaveparade) enables the same thing - the LED will constantly emit light and fade out when a signal is applied
Hope this helps! Smile
Ciao!
voltage to resistance schematic
 Filesize:  97.75 KB
 Viewed:  616 Time(s)
