rc_hoffmann
Posted: Sat Jan 09, 2016 9:44 am Post subject:
Living Vocoder - re-run 2016(!) |
Hey,
over the last months a couple of people asked about the Living Vocoder, so I had the idea of doing a limited R&D (re-)run of Jürgen's original 20 band Living Vocoder pcb (100% identical to the original monster pcb released in 2011). As you probably know, Jürgen called it in "debugging state", so this is not a finalized design - my idea is to start another joint beta-phase in order to resume this project, identify and fix any issues or required adjustments, so this is clearly aimed at people both experienced and crazy enough to take this on.
Run will be limited to 20-30 pcbs max (each pcb is appr. 40cm x 30cm! - see photo)!
Price will be in the range of € 100-120 per pcb + shipping (original price was € 300), but please note that this is not a cheap or simple project. More info on the original board: http://jhaible.com/legacy/vocoder/living_vocoder.html
I started an interest check to see if there are about 20-30 people up for this challenge and resonance has been quite strong, so it not only looks like this will happen (ever), but rather that I may be able to order the boards in the next days(!)
If you're definitely interested, please shoot an email to vocoder(at)jhaible(dot)com - Thanks!
 _________________ Random*Source: Serge, Haible & more. Facebook: https://www.facebook.com/randomsource |
JanneI
Posted: Tue Mar 01, 2016 4:21 pm Post subject:
Re: Living Vocoder - re-run 2016(!) |
Group buy for the 1% caps? Anyone? |
b-funk
JanneI
Posted: Sun Mar 13, 2016 9:50 am Post subject:
I'm already there! Thanks anyway! Cheers!
Techman
Posted: Wed Aug 16, 2017 7:43 am Post subject:
Thought I'd resurrect this thread
This is a completed and working vocoder using a board from Random Source.
Description: |
Filesize: |
1.31 MB |
Viewed: |
621 Time(s) |
Description: |
Filesize: |
1.71 MB |
Viewed: |
549 Time(s) |
Description: |
Filesize: |
1.37 MB |
Viewed: |
535 Time(s) |
snorkeldata
Posted: Mon Sep 04, 2017 8:39 am Post subject:
Wow!!! That thing looks amazing! Do you have any samples? |
