Streaming now
Sinister Tone Generator
Page 1 of 1 [20 Posts]
rich decibels
PostPosted: Wed Jun 01, 2011 3:49 am    Post subject: Sinister Tone Generator
Subject description: Bass drone synth
Hello people I made a little drone synth. It is not especially clever and maybe not the first time someone's thought of this set-up but it is especially fun to play and nice to look at. This specific one that I built is for sale, with all proceeds going to a good cause. Further details are up on my site. Please enjoy.
Here's a sample, with reverb and filtering added from 1:18
Update: Schematic updated as per richardc64's suggestion below
RF
Audio files: 28
PostPosted: Wed Jun 01, 2011 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice job - very nice packaging and good sounds...
bruce
www.sdiy.org/rfeng
tjookum
Audio files: 26
PostPosted: Wed Jun 01, 2011 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent work and very clever usage of all of the 6 inverters. I really like how you paired them together with those little 10k seperation pots, I don't think I've seen that before and it sounds fantastic.
What kind of good cause are you supporting?
Hunter S. Thompson
movies
noise
Psyingo
PostPosted: Wed Jun 01, 2011 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
fine tune is realy good for drons
richardc64
Audio files: 26
PostPosted: Thu Jun 02, 2011 7:23 am    Post subject: Re: Sinister Tone Generator
rich decibels wrote:
It is not especially clever...
I don't know about that. Having oscillators track while maintaining an offset ("separation") seems pretty clever to me. That center off switch might cause problems, though. Shorting either output directly to ground doesn't seem like a good idea.
rich decibels
PostPosted: Thu Jun 02, 2011 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your comments esteemed brethren! Any ideas for a better way of switching one or the other voice off without grounding the output? I guess if I ground the inputs of inverters C and D instead of the outputs that should still work, right?
richardc64
Audio files: 26
PostPosted: Fri Jun 03, 2011 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
That would then be grounding the oscillators' outputs. (Thru the diodes.) Instead of grounding the Inputs of C or D, wire the switch to +V so it makes C or D In logic 1. That will disable the diode ORing and hold C or D Out at logic 0; the same effect as grounding either output was having, but without the excessive, possibly damaging, current flow.
Nice, compact package, btw.
PostPosted: Fri Jun 03, 2011 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Rich, Would you be so kind as to show us your veroboard design layout too? Smile
ACHTUNG!
rich decibels
PostPosted: Fri Jun 03, 2011 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks c64, I'll give it a go.
v-un-v my layout is something fairly similar to this: http://www.flickr.com/photos/rdbartlett/5785949516
PostPosted: Fri Jun 03, 2011 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
super-cool! Thx! Very Happy
ACHTUNG!
rich decibels
PostPosted: Wed Jun 29, 2011 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
fyi I've recorded a new demo of this unit running through a WSG filter with shitty LFO (deets about that at my site)
Sinister Tone Generator thru WSG LPF and junky LFO by Rich Decibels
donpachi
PostPosted: Wed Aug 03, 2011 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I built this (standard four-knob version without filters). It is most excellent and totally awesome. It does my favorite WSG sounds in a smaller package and from a quick afternoon build. Sounds great through a guitar amp with reverb, but I'll try different filters soon.
Do not hesitate to order the dual pots for this!
Inventor
Audio files: 267
PostPosted: Thu Aug 04, 2011 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
rich decibels, did you sell it yet and at what price? I'd like to get into making boxes like this and would like to know what people pay for them.
Les
rich decibels
PostPosted: Sun Aug 07, 2011 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Les
This unit sold at auction for $120 (NZD). Too cheap in my opinion, but I'm not sore because the money was for charity. I have had better experience selling my stuff as art objects as opposed to off-the-shelf products, I recommend that approach to everyone. Unless of course you've just designed the Next Big Thing and you can mass produce it for $10 a piece, there's just no point targeting the consumer market.
Make sense?
Inventor
Audio files: 267
PostPosted: Sun Aug 07, 2011 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that's a really good price actually. I see what you mean about the art object concept - huh, I'll have to give that some thought.
Les
rich decibels
PostPosted: Wed Aug 10, 2011 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Les I just finished writing a tutorial on how I make my laser-cut electronics enclosures like this one, thought you might be interested.
It covers the process from circuit design and layout, to parts + controls placement, to laser-cut construction techniques, including a few tricky things like allowing for kerf and dog-boning your internal corners to prevent cracking.
Hope it is of some use to you Smile
SPIKE the Percussionist
PostPosted: Wed Aug 10, 2011 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Rich...
That noiz toy sounds really neat!
if you decide to make more please let me know.
i would like to get one!
[[more noiz!]]
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Troupe Music Director
DOGGEBI
morgue city
Inventor
Audio files: 267
PostPosted: Thu Aug 11, 2011 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
rich, my compliments on your enclosure technique, it's very well developed. I like how the dog bone cutout serves to relieve the stress of the fastener, and also fits the fastener.
You know what occurs to me is that you could make other non-rectangular shapes of box this way. You could even make lego-style U-shaped boxes or consoles of some sort. I guess now that you've mastered this technique, the rest is limited only by your imagination!
Les
jeanpat
PostPosted: Sun Feb 25, 2018 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
I made a sinister tone augmented. The start was Rich design, I change the range of two oscillators, add a mixer to get more balance when both side are on. I also add a three shapes LFO on each side (borrow from mfos). Si here it is.
https://youtu.be/V8MI5q4ddZk
 Filesize:  81.72 KB
 Viewed:  327 Time(s)
rich decibels
PostPosted: Sun Feb 25, 2018 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
jeanpat thanks so much for sharing! I am so impressed with what you've built, you made my day Smile
