is this acceptable?
Page 1 of 1 [5 Posts]
mike page
PostPosted: Mon Jun 18, 2018 10:05 am    Post subject: is this acceptable? Reply with quote  Mark this post and the followings unread
having two 4051's sampling from the same bank of voltage dividers?
oh but with buffers at cv 1 & 2
PostPosted: Mon Jun 18, 2018 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
As long as the inputs of the buffers are high impedance that should be fine. Not that it would break anything otherwise but it
could affect the voltages, they'd still be the same for both though. At least that's what I think, I've never actually tried it.
mike page
PostPosted: Mon Jun 18, 2018 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent Smile thanks
IGR
PostPosted: Tue Jun 19, 2018 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Why did you choose exactly 0167? I'm very curious about what you're building!
Steveg
PostPosted: Sat Jun 23, 2018 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a similar design using capacitors rather than pots. As many 4051s as you wish can read out the waveform at different frequencies.
@IGR ... nothing significant about 0167 ... Mike just has 8 potentiometers which he as numbered 0 through 7 because they connect to inputs 0 through 7 of the 4051. But to reduce repetition he has only drawn the first and last two.
