Infinite ringing on string oscillator?
Page 1 of 1 [3 Posts]
jamos
G2 patch files: 41
PostPosted: Sun Sep 02, 2018 6:25 pm    Post subject: Infinite ringing on string oscillator? Reply with quote  Mark this post and the followings unread
I have been working with guitar sounds a lot lately, stuff based on the string oscillator - and have discovered that, occasionally, one or more voices will continue ringing at a low volume indefinitely. the only way to stop it is to raise the Damping value slightly. This happens even with moderate damping values. I am too lazy to put up a patch at the moment but two of them I am hearing this with are my own Koto patch, and Chet's plucked guitar patch, both in the patch libraries.
Anyone have a clue?
varice
Audio files: 29
G2 patch files: 54
PostPosted: Mon Sep 03, 2018 2:15 am    Post subject: Re: Infinite ringing on string oscillator? Reply with quote  Mark this post and the followings unread
Anyone have a clue?
Is it possible that there is still a signal on the OscString input? What happens if you disconnect the input or force the input signal to zero level?
Electromagnetic Wave
G2 patch files: 38
PostPosted: Mon Sep 03, 2018 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I guest this is the buggy delay part again ...
Edit : I saw you use a EQ module in your Koto patch. Do you use EQ module for Chet patch too ? I ask because EQ module can produce this type of bug too
