Compile code for AVR Atmega48. Dredrum I need help.
Page 1 of 1 [12 Posts]
emiz
PostPosted: Wed Sep 05, 2018 7:07 pm    Post subject: Compile code for AVR Atmega48. Dredrum I need help.
Subject description: Dredrum builders here?
Hi
i bought a unoffical dredrum pcb from ebay..
the assembly was no problem.
but now i don´t know how to compile the code. the buran electrix site is down
i emailed the owner and he said he couldnt give me support because its an unofficial pcb not from his production.
on the github there is only a archive with 3 files dredrum.c 8bitsinetable.h and a make file.
could anybody tell me how to get a hex file from this archive.
PostPosted: Wed Sep 05, 2018 11:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would help a lot if you provide a link to the github you mention so one could have a look at the schematics and code.
With the little info you give there is nothing I can do for you.
my synth
emiz
PostPosted: Thu Sep 06, 2018 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
https://github.com/buranelectrix/dredrum
theres a avrisp 6 pole socket on the pcb
PostPosted: Thu Sep 06, 2018 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
first you need a program which is free to download, called Atmel Studio.
download it HERE
then start a new project and use the code from the github, compile and upload to your board.
for uploading you can use a tool like the avrisp or use an arduino to flash, but you have to google the howto.
btw I’m not a dredrum builder, just an atmel enthousiast...
my synth
emiz
PostPosted: Thu Sep 06, 2018 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
download it HERE
thanks for the info. my internet pc is still running on windows xp, atmel studio 7 is not supportet by winxp, so i downloaded atmel studio 6.2.
now i can´t find the "compile" function i tried "save as" but i found nothing to save or convert the project as .hex file.
can you tell me which format do you use to upload the code to avr?
i got a "deek-robot usb-tinyisp" stick.
PostPosted: Fri Sep 07, 2018 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Before compiling you have to do three things:
First change the line where it says:
#include "./8bit_q_sine.h" into: #include "8bit_q_sine.h" and copy 8bit_q_sine.h to the map where main.c is.
in the file 8bit_q_sine.h you have to change:
PROGMEM prog_char q_sine_table[] = { to PROGMEM const char q_sine_table[] = {
this is because prog_char is not used anymore.
There are two ways to compile and transfer the data, since I only have studio 7 I will upload some screenshots from this version, but I think they are quite similar.
Ok, once you have your project ready you can either click on Build >> Build Dredrum
Now the code is compiled, now click on the icon with the flash:
and a menu is opened:
Where you can set your processor, isp clock frequency etc.
If you read your device signature right you may proceed to clicking on Memories:
Just click on Program and that is it.
Another way of compiling and flashing is to click on the play button:
 Filesize:  9.31 KB
 Viewed:  10733 Time(s)
 Filesize:  12.5 KB
 Filesize:  65.53 KB
 Viewed:  373 Time(s)
Dredrum.hex
This is the hex file from Dredrum_Gate
 Filename:  Dredrum.hex
 Filesize:  7 KB
 Downloaded:  506 Time(s)
Dredrum.hex
This is the hex file for Dredrum_trig
 Filesize:  6.88 KB
 Downloaded:  458 Time(s)
my synth
emiz
PostPosted: Fri Sep 07, 2018 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much Very Happy
This is really helpfull
I´ll try it tonight with Atmel Studio 6.2, if it doesn´t work i have to download Atmel Studio 7 to my music pc who´s usually not online.
Thanks a lot
PostPosted: Fri Sep 07, 2018 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
you could try to use one of the hex files I provided Cool
my synth
emiz
PostPosted: Fri Sep 07, 2018 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah your hex file worked. i used a program called avrdudess 2.4
[img][/img]
i´ve tried it without setting the baud rate and bit clock.
the interface seems to work the leds light up when i push buttons
but the sound is very distortet it seems like it where totaly pitched down.
i think it must have something to do with the external oscillator.
dredrum uses a 20mhz quarz oscillator. do i have to set the baudrate or the fuse bits correspondending to this?
i have a very high very loud beep tone all the time on the output and the voice from the module is pretty quiet.
or is there a difference between atmega48 and atmega 48p? i have atmega 48 without p.
 Filesize:  42.19 KB
 Viewed:  391 Time(s)
New postPosted: Sat Sep 08, 2018 2:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I have compiled it using the settings for an atmega48 (without the p)
But I don't know the meaning of your fuse settings:
So I can't tell really, could you make a screenshot of the fuse for the clock generation?
You should choose something like "external full swing crystal" and uncheck the fuse for low.ckdiv8, but make sure you leave high.spien CHECKED!!
HERE you could look at the calculation for the fuse settings.
 Filesize:  12.55 KB
 Viewed:  10600 Time(s)
my synth
emiz
New postPosted: Sun Sep 09, 2018 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
yeahah Smile it finally works. thanks for your help . Very Happy
used the fuse calcutor tried some values for full swing oscillator and unchecked clock divide by 8 and disabled internal oscillator output.
HUGE THANKS
New postPosted: Sun Sep 09, 2018 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
your’e wellcome Very Happy
my synth
