How to Exclude one note of the keyboard ?
Page 1 of 1 [6 Posts]
chapelier fou
PostPosted: Tue May 14, 2019 1:37 am    Post subject: How to Exclude one note of the keyboard ? Reply with quote  Mark this post and the followings unread
I don't seem to get how to make a split point in the keyboard.
What I want is use one specific key to trigger one specific action. I do this with the Note Detector. But I want this specific note to be excluded from the rest of the patch.
My intuition would be to make three keyboard zones, one for the specific note, and two others for below and above it.
What am I missing obvious ?
chapelier fou
PostPosted: Tue May 14, 2019 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I just discovered the "Keyb" option on the channel parameter of the NoteZone, and the "this", "slotA", etc options in the destinations, but still can't figure it out.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed May 15, 2019 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome
Say you have your specific action patch in slot A, Add two NoteZone modules into the fx area. The way they are set in this example, another poly patch in slotB will respond to any key except C4.
Make sure SlotA has the keyboard focus.
NoteZone (the dead zone)
 Filesize:  9.03 KB
 Viewed:  5669 Time(s)
chapelier fou
PostPosted: Wed May 15, 2019 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks.
It won't work because I will use it playing the keyboard live (in this case slot B), so it needs to be on the same slot.
I managed to find a solution using a combination of Level Comparator, Switch, and Logic Gate.
It works perfectly but it's a pity to patch in comparison to how the Keyboard Zone Midi Module works.
EDIT : I think your solution works perfectly. But still, using one Slot is preferable.
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Jun 01, 2019 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey!
"to make three keyboard zones, one for the specific note, and two others for below and above it."
"But still, using one Slot is preferable."
Check this : http://electro-music.com/forum/topic-57432.html
& this : http://electro-music.com/forum/post-383997.html#383997
Need a lot more resources but it's a good solution to do this in 1 slot.
chapelier fou
PostPosted: Sun Jun 02, 2019 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much !
