LFO 2 no triangle or sine waves
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
RyBowk
PostPosted: Thu Nov 21, 2019 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha, never. I’ll only learn by perseverance
gabbagabi
PostPosted: Thu Nov 21, 2019 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
nice new word: perseverance, dunno if i will remember it
i checked the soundtronics-site,
the pcb are looking the same like yves, they even use the original documentation
so can we assume that we can use tis as orientation?
where did u placed the probe for the scope, when it was on DC?
RyBowk
PostPosted: Thu Nov 21, 2019 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Pin14 of ic 2
gabbagabi
PostPosted: Thu Nov 21, 2019 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
ok,
there u should measure a signal that is going from -3,5V to 3,5V
the scope schoots saying that the signal is going from 0V to 7V
that means ether u did not used the ofset trimmers, or they dont work
connect the scope again on pin 14 and try to play around with (both) offsettrimmers to test it
you also could try to measure on the middle pins of the trimmers, when you turn the trimmers u should be able to measure a voltage that goes from 0V to ~10V, on BOTH
RyBowk
PostPosted: Thu Nov 21, 2019 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
So I’m getting 7.6volts from both trimmers
RyBowk
PostPosted: Thu Nov 21, 2019 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Measuring the power directly as it comes in pre 10ohm resistors is 12v, directly after the resistors I’m reading 11.83v. Please excuse my naivety but would this be normal?
PostPosted: Thu Nov 21, 2019 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
12 - 11.83 = 0.17 or 170 mV.. over 10 Ohms and that would mean 17 mA of power consumption .. nothing unusual I think?
RyBowk
PostPosted: Fri Nov 22, 2019 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for clearing that up mate. I feel like I’m learning more everyday with you guys
gabbagabi
PostPosted: Fri Nov 22, 2019 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
so u have measured 7,6V on both middle pins on the symetry trimmers?
then have turned the trimmers up and down and nothing changed?
u also measured at pin14, turned the trimmers up and down, and the SAW-Wave did not changed position in relation to the 0V Line on your scope?
what do u measure on the other (outer) pins?
RyBowk
PostPosted: Fri Nov 22, 2019 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I was tired yesterday,
They both measure from 0 - 7.6 when turned.
But neither affect the rising ramp from pin 14
I’ll take some more measurements when I’m home. Thanks Ryan
gabbagabi
PostPosted: Fri Nov 22, 2019 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
no problem,
can u measure if this variable voltage is comming tru to R15? u have to use the end which is not connectet to pin2/ic2
try both trimmers and since there is the range switch inbetween, use both switch positions
 Filesize:  189.46 KB
 Viewed:  4979 Time(s)
