de:Beer
JovianPyx
Audio files: 224
Posted: Thu Jan 30, 2020 6:20 am Post subject:
That is a standard common emitter amplifier. As such, the collector resistor controls the gain. The larger the resistor's value, the more gain. I would try 4.7K to start with and see what happens - this will be a cut-and-try experiment because there is only cursory information about the circuit.
Also R1 seems quite low and could be shunting a lot of the input signal to ground. I'd work with R2 first, but if acceptable results are not achieved, try raising the value of R1, I'd start at 1K and see if it gets more amplitude (and still sounds correct). _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Thu Jan 30, 2020 12:29 pm Post subject:
I had some varying results with adding line-outs to toys and the like. Often it sounds better through the speaker which has mostly to do
with the limited bandwidth and response. A line out usually creates a much harsher sound. It can help to leave the speaker in place,
not sure if that is because of the inductance. Also replacing it with a low value resistor can sometimes improve the sound quality a bit.
At least it just has a single switched output, sometimes they have two outputs directly from a chip which can be a bit to tricky to interface with. _________________ "My perf, it's full of holes!"
de:Beer
Posted: Thu Jan 30, 2020 2:17 pm Post subject:
Thank you JovianPyx and PHOBoS for the reply!
I tryed a few resistors and it only produced a stable sound around 25 ohm.
Wich definitly a value I did not expect. But if it works it works.
So that is what I have put in place now and it sounds glorious, in a circuit bended way ofcourse.
Once everything is done I will do my best to post some photo's of the device and some sound files.
Thanks again for the help! |
JovianPyx
Audio files: 224
Posted: Thu Jan 30, 2020 3:19 pm Post subject:
Once I saw PHOBoS's reply, I had thought the same, since it's a toy it might want a smaller resistance due to being designed to drive a speaker. Good that it works now. _________________ FPGA, dsPIC and Fatman Synth Stuff
