Trouble patching Wren
Page 1 of 1 [7 Posts]
Airlock
Audio files: 53
PostPosted: Fri Jun 26, 2020 2:02 pm    Post subject: Trouble patching Wren
Subject description: Failing braincells possibly...
Jan, when you get a chance could you help me with patching so that I can use a MIDI keyboard with Wren? I did mange to do this a while ago but beats me why I can't suss it out now. I'm stumped, there must have been an example somewhere at one time that I can't find now; and the guy who was doing YouTube videos made them private. Thank you in advance!
 Filesize:  6.47 KB
 Viewed:  4229 Time(s)
Audio files: 297
PostPosted: Fri Jun 26, 2020 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure .. the note out goes to the freq input od the osc .. the gate out could trigger an envelope .. the velocity - on output can go to the envelope am input or to the osc's am input ..
from the menu .. Setup/MIDI devices .. select a MIDI device there for input.
I'll do a patch for you when needed .. but probably doable with this info?
Audio files: 297
PostPosted: Fri Jun 26, 2020 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
So .. like this:
Audio files: 297
PostPosted: Fri Jun 26, 2020 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or when you want a couple of notes playing:
Airlock
Audio files: 53
PostPosted: Fri Jun 26, 2020 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
salut Thanks jan!
Airlock
Audio files: 53
PostPosted: Fri Jun 26, 2020 6:40 pm    Post subject: Trouble patching Wren
Imagine my shock when the first example didn't work! A reboot solved whatever the problem was. Thanks again jan!
Audio files: 297
PostPosted: Fri Jun 26, 2020 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah good .. I didn't test it myself .. as the MIDI routing runs trough a G2 .. but that one had a wrong patch loaded .. and didnt feel like firing it's editor up Shocked
