strange error patch
Page 1 of 1 [7 Posts]
gentlclockdivider
PostPosted: Sun Apr 12, 2009 5:35 am    Post subject: strange error patch Reply with quote  Mark this post and the followings unread
Can someone confirm this ...
I just want to know if ther'e something wrong with my modular .
There's crackled noise all over the place ....It only happens when the outputs are routed to the common voice area
JUst press some keys thanks
error2.pch
error patch
 Filename:  error2.pch
 Filesize:  2.32 KB
 Downloaded:  264 Time(s)
gentlclockdivider
PostPosted: Sun Apr 12, 2009 5:42 am    Post subject: better example Reply with quote  Mark this post and the followings unread
I downloaded the patch from the web and I jyst don't know where the crackles come from
I really think there's something wrong my modular
error3.pch
 Filename:  error3.pch
 Filesize:  2.13 KB
 Downloaded:  248 Time(s)
error3.pch
 Filesize:  2.13 KB
 Downloaded:  271 Time(s)
gentlclockdivider
PostPosted: Sun Apr 12, 2009 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
smame with this patch
It all happens in the commn voice area
PoorHouserror.pch
 Filename:  PoorHouserror.pch
 Filesize:  3.04 KB
egw
G2 patch files: 8
PostPosted: Sun Apr 12, 2009 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Probably what your hear is the "Slot D Bug" which causes crackling noises on the patch on slot D under certain conditions. I'm not sure what the conditions are, but I believe it only happens when using the poly area in slot D.
www.gregwaltzer.com
gentlclockdivider
PostPosted: Sun Apr 12, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
yes I just found out I have the distorted crackling only in slot D
D'you have the same problem ?
egw
G2 patch files: 8
PostPosted: Sun Apr 12, 2009 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
It has something to do with allocating voices across the slots, I don't remember the details. I avoid it by only using mono-type patches in slot D.
www.gregwaltzer.com
gomidas
G2 patch files: 6
PostPosted: Sun Aug 30, 2020 4:27 am    Post subject:   Reply with quote  Mark this post and the followings unread
11 years later..., YOU JUST SAVE MY DAY!!!!!!!! Very Happy
I was starting to think that my 22 year's old Nord Modular was getting tired, no problem I see you in 2040!!!! Thanks
Take care and Electro-Music 4 EVER Twisted Evil
