Need ideas for what to do with this cool old part
Page 1 of 1 [5 Posts]
Banjo
PostPosted: Tue Aug 25, 2020 8:36 am    Post subject: Need ideas for what to do with this cool old part Reply with quote  Mark this post and the followings unread
This old rotary selection switch was in a box of electronic parts my dad had. The eleven dial plate is screaming to be used on a master volume pot. The rotary switches are what I’m looking for ideas for.
It looks like a typical piece of hardware from the cockpit of an aircraft from the sixties and seventies. I used to set the tower frequency for the aircrew before they showed up back in the day.
I’m thinking of just building a panel with ten inputs and one output for each dial, instead of dedicating it to a specific task. It will be several months at least before I use it, so I’d like to hear your ideas. Thanks!
 Filesize:  2.04 MB
 Viewed:  328 Time(s)
transponderfish
PostPosted: Tue Aug 25, 2020 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
It goes to 11! You found the holy grail!
PostPosted: Wed Aug 26, 2020 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I have used two similar switches in my sequencer to set the number of pulses or length for each step.
my synth
Banjo
PostPosted: Sun Aug 30, 2020 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Transponderfish, my jaw dropped when I came across that plate.
Grumble, thats kinda along the lines of what my original ideas for those switches were. I'm leaning at the moment to something that I can feed whatever I want into it. 44 jacks will take up a fair amount of space, but the more I think about it, the more possibilities I see. Cool videos and sounds by the way!
Perhaps I should cut a panel big enough to hold all 40 inputs and 4 outs, but only drill enough to use one of the rotaries just to see how well it works in reality. The metal I get for free at the scrap yard. I need to order more jacks anyway.
Still looking for more ideas
piedwagtail
PostPosted: Wed Sep 09, 2020 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thumbwheel selector switch in a Lunetta environment = 4522B for preset decade down counter division
or 40102B for a pair
clock/n or frequency synthesis with 4046 -see EMM Harmonic Engine
R
