A TRANSISTOR-LESS SOUND SYNTHESIZER
Page 1 of 1 [4 Posts]
Steveg
PostPosted: Mon Oct 26, 2020 4:18 pm    Post subject: A TRANSISTOR-LESS SOUND SYNTHESIZER Reply with quote  Mark this post and the followings unread
Did anyone notice this? https://hackaday.com/2020/10/24/a-transistor-less-sound-synthesizer/
I'm wondering if the supply voltage across the two oscillator LEDs needs to be less than the sum of the voltage drop across them so both don't light up at the same time?
But a very cool bit of noise maker.
dk
PostPosted: Tue Oct 27, 2020 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, cool. Awesome drone sounds!
On his schematic it looks like they're getting 5V: https://cdn.hackaday.io/images/5964711602672729170.JPG Since it looks like he's using blue LEDs, I guess that would be the case?
Steveg
PostPosted: Tue Oct 27, 2020 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was my thought as well but nowhere is that called out in Dr Cockroach's or Patrick Flett's videos.
And confirmed by Patrick as a requirement.
dk
PostPosted: Wed Oct 28, 2020 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thinking about it further, I'm curious what kind of levels he's getting out of this. The LDR's I have can't make it into audio rates period, but assuming he's using something faster, I can't imagine much swing coming out?
Also, his RTA isn't using a very narrow resolution, but it seems that there is at least a few octaves of harmonics on top, mixed in with noise - most of which I would guess is attributed to the diodes. I'm wondering if you couldn't get similar sonic results by just running a triangle wave through a bridge rectifier without dealing with the rest of the mess. I know that it would lack the novelty, but you'd get a lot more range with a lot less fuss.
