could someone check this chorus layout quick, thx
Page 1 of 1 [4 Posts]
floating-water
PostPosted: Tue Nov 17, 2020 3:01 am    Post subject: could someone check this chorus layout quick, thx Reply with quote  Mark this post and the followings unread
Found this 'one-chip chorus' made with a pt2399 you may have heard about but the threads these layouts are attached to meander wildly into issues people may have found and my knowledge of electronics is still relatively embryonic at this point. could someone who knows their s*** have a quick scan. I would just breadboard it but im waiting for more in the post
There's two; what I believe to be the original:
And a cleaner layout:
I'm a bit confused by them because I believe pin 3 & 4 should always be grounded on the 99's and I can't find that in the layouts, i might be being a dumbass tho, thanks
PostPosted: Tue Nov 17, 2020 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
You are correct, pin 3 and 4 should be both connected to gnd (analog gnd and digital gnd) that looks like an error in both the layouts.
Edit:added some words
ElectroSmash - PT2399 Analysis.pdf
 Filename:  ElectroSmash - PT2399 Analysis.pdf
 Filesize:  2.56 MB
 Downloaded:  687 Time(s)
my synth
flagada
PostPosted: Tue Nov 17, 2020 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the upper lay out, 3 and 4 are grounded, aren't they?
EDIT: now looking a bit better, 4 does not seem to be.
khakifridge
PostPosted: Fri Nov 20, 2020 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Pins 3 and 4 are connected internally by a low-value resistor. Many schematics don't show them connected for this reason, including the original schematic by "anchovie" from which these layouts are derived.
Real-world experience suggests YMMV. It's easy enough to bridge the pins with solder or a small link if you find it's needed.
