Does anyone has been able to fix an USB damaged board?
Page 4 of 4 [76 Posts]
3phase
G2 patch files: 141
PostPosted: Fri Dec 10, 2021 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
you better use the correct tools to replace the usb chip. its done with a reflow station.. basically a small hot air gun.. and special flux that contains soldring tin particles..
using normal soldering tools probably results in broken threads onnthe main board..
