NMG2 unresponsive switch buttons
Page 1 of 1 [7 Posts]
chapelier fou
PostPosted: Wed Nov 16, 2022 8:15 am    Post subject: NMG2 unresponsive switch buttons Reply with quote  Mark this post and the followings unread
On my G2, 50% of the switches (like octave or variation selection) are very little responsive. I need to push them HARD to register the press.
Is it a common issue ? Any advice to give them their youth back ?
dorremifasol
G2 patch files: 49
PostPosted: Wed Dec 21, 2022 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
In my experience, every Nord synth I have had (and these are many) needed the love of some contact cleaner in the buttons eventually. Fortunately all the Nord synths are really easy to disassemble.
Albert
chapelier fou
PostPosted: Thu Dec 22, 2022 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll take care of my beloved G2, then !
Burp
G2 patch files: 7
PostPosted: Fri Feb 24, 2023 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Before using contact-cleaner, try pressed air to clean them. At least i did and all my buttons work again.
if you don't know where you're going, you will allways arrive
chapelier fou
PostPosted: Thu Mar 30, 2023 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Help!
So I dismantled the control panel of my G2, but I'm not sure how to remove the switch caps without damage. Any tips ?
EDIT : found this : https://www.phase57.com/build/nord-modular-repair/buttons/
jamos
G2 patch files: 41
PostPosted: Sat Apr 01, 2023 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
They do come off pretty easy. Just a squeeze and they will pop out.
One bit of advice: while you are in there, clean all of them, even though it is a daunting task. I opened mine to do the Store button, but missed another button that I forgot about. So I have to open it again, later.
chapelier fou
PostPosted: Sun Apr 02, 2023 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks @jamos.
I took the time to clean them all (isopropyl alcohol, then a touch of contact cleaner). Had to reopen 2 times though, to fix some switches that were still unresponsive, and also one switch that was mechanically stuck due to screwing the PCB too tight.
Also I couldn't unscrew the pitch stick as one of the screws was damaged, so the operation was a bit tricky.
All in all it's not that trivial, but it's now working perfectly !
