Acoustic Drums Physical Models and Feedback
Page 1 of 1 [2 Posts]
rrooyyccee
G2 patch files: 10
PostPosted: Sat Oct 05, 2024 7:03 pm    Post subject: Acoustic Drums Physical Models and Feedback Reply with quote  Mark this post and the followings unread
I've attached three patches that when loaded into slots A, B, and C and set to a single midi channel makes up an acoustic drum kit. I tried to use physical models where I could. Patch A is a feedback based kick and a Karplus Strong based snare. Patch B is a tom that uses feedback and the build in percussion oscillator. Patch B was my attempt at a physical model of a cymbal along with hihats. The snare I think is pretty effective and I feel is complete. The tom is not convincing and another approach is needed: I had trouble finding a stable model that had bit and sounded like a real tom. From past experience, this comes down to the exciter (noise burst) being shaped to create the illusion of a beater.The cymbal uses 3 FM oscillators with recurrent feedback loops to generate metallic partials. The drum voices are mapped from C2 to Bflat3.
A. PM KickSn.pch
 Filename:  A. PM KickSn.pch
 Filesize:  3.25 KB
 Downloaded:  100 Time(s)
B PhysMod Tom.pch
 Filename:  B PhysMod Tom.pch
 Filesize:  1.92 KB
 Downloaded:  92 Time(s)
C Acoustic cymbval.pch
 Filename:  C Acoustic cymbval.pch
 Filesize:  1.56 KB
rrooyyccee
G2 patch files: 10
PostPosted: Sat Oct 05, 2024 8:44 pm    Post subject: Updated versions Reply with quote  Mark this post and the followings unread
These are updated versions. The "B" patch is a physical model of a tom. I played around with a floor tom in the studio and decided that the beater needs to be modeled more carefully. I also worked on the ride cymbal in the "C" patch, trying to capture ride cymbal dynamics more accurately.
A. PM KickSn.pch
 Filesize:  3.25 KB
 Downloaded:  78 Time(s)
B PhysMod Tom.pch
 Filesize:  2.49 KB
C PhysMod HHCymb.pch
 Filename:  C PhysMod HHCymb.pch
 Filesize:  4.02 KB
 Downloaded:  86 Time(s)
