 Forum index » Instruments and Equipment » Cwejman Sound
S-Triggers
Page 1 of 1 [4 Posts]
monads
PostPosted: Wed Nov 02, 2005 10:37 am    Post subject: S-Triggers Reply with quote  Mark this post and the followings unread
Hi all!
Can someone explain to me s-triggers and or tips for using the analogue input s-trigger on the S1? I understand the theory of gates and triggers but this s-trigger business has me a little dumbfounded. I guess early Moogs for example used s-triggers?
PostPosted: Wed Nov 02, 2005 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah.. the shorting/switch trigger
http://arts.ucsc.edu/ems/music/equipment/synthesizers/analog/moog/Moog.html
http://www.synthesizers.com/gates.html
http://machines.hyperreal.org/features/before-midi.html#trigger
minimoog owners manual.pdf
 Filename:  minimoog owners manual.pdf
 Filesize:  264.33 KB
 Downloaded:  1121 Time(s)
Flickr
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Nov 02, 2005 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same function as a gate, different electrically. I think the Korg MS series also used S-Trigger but with a conventional 6mm socket. If the S1 has both gate and s-trigger it would just be for compatability with other gear.
monads
PostPosted: Wed Nov 02, 2005 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Much thanks guys! Those links are helpful too. The S1 has both Gate, Trigger, and S-Trigger analogue inputs on the back of the unit.
