Strange rumbling in g2 box
Page 1 of 1 [8 Posts]
sidx
PostPosted: Wed Jun 14, 2006 5:32 pm    Post subject:  Strange rumbling in g2 box Reply with quote  Mark this post and the followings unread
Hi
I have strange rumbling noise inside my 3octaves G2
It can be heared only in a full silence but i cant remember that i heared it before.Tell me please is that normal? All functions are ok.
PostPosted: Thu Jun 15, 2006 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
That would be small swedish trolls? Shocked
One of the few things that can actually make a noise is the transformer. It is quite normal and it could at times be described as a rumbling. Hey, can you record this sound? Very Happy
Flickr
Audio files: 306
PostPosted: Thu Jun 15, 2006 3:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Most Clavia gear seems to do this (my G2 engines and both my NM Classics), I think it to be due to the steel case, the trnsformer being mounted on a PCB and the two interacting magnetically.
PostPosted: Thu Jun 15, 2006 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Basically a transformer is vibrating and there is a fluctuating magnetic field around it. It is quite normal to hear both mechanically transferred noise and at times also electromagnetically induced nose.
Flickr
sidx
PostPosted: Thu Jun 15, 2006 5:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
dunno guys...very quite noise can be heared in a full silence...but its stable
and when i took out front panel to check what is problem (!?) - noise was stable also...i guess it going from this little blue box as u say - transformator.Paranoia?
PostPosted: Thu Jun 15, 2006 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
The usual description should go more like a humming rather than a rumbling. Bad transformers may at times actually make a rattling noise. I guess you shouldn´t worry. Transformers are supposed to make some noise. THis is quite normal.
Flickr
sidx
PostPosted: Fri Jun 16, 2006 6:27 pm    Post subject:   Reply with quote  Mark this post and the followings unread
oki thanx for info now im ok
3phase
G2 patch files: 141
PostPosted: Fri Jun 16, 2006 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
actually they shouldnt...its rather a sign that the inbuild transformers are too tight dimensioned... If magnetic flux is the reason a round coil transformator would do the job..but they are much more expensiv than the standard modell used by clavia.
If a very sensetiv person really suffers from that noise it would be possible to get rid of it...
But in reality..this noise is much lower than the noise my computer makes...
