sidx
Joined: Jun 05, 2005 Posts: 20 Location: Russia,Moscow
Posted: Wed Jun 14, 2006 5:32 pm Post subject:
Strange rumbling in g2 box |
Hi
I have strange rumbling noise inside my 3octaves G2
It can be heared only in a full silence but i cant remember that i heared it before.Tell me please is that normal? All functions are ok.
Cheers |
Posted: Thu Jun 15, 2006 1:02 am Post subject:
That would be small swedish trolls?
One of the few things that can actually make a noise is the transformer. It is quite normal and it could at times be described as a rumbling. Hey, can you record this sound?  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Joined: Apr 03, 2004 Posts: 24505 Location: The Netherlands, Enschede
Posted: Thu Jun 15, 2006 3:21 am Post subject:
Most Clavia gear seems to do this (my G2 engines and both my NM Classics), I think it to be due to the steel case, the trnsformer being mounted on a PCB and the two interacting magnetically. _________________ Jan
Posted: Thu Jun 15, 2006 3:27 am Post subject:
Basically a transformer is vibrating and there is a fluctuating magnetic field around it. It is quite normal to hear both mechanically transferred noise and at times also electromagnetically induced nose. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
sidx
Posted: Thu Jun 15, 2006 5:24 pm Post subject:
dunno guys...very quite noise can be heared in a full silence...but its stable
and when i took out front panel to check what is problem (!?) - noise was stable also...i guess it going from this little blue box as u say - transformator.Paranoia? |
Posted: Thu Jun 15, 2006 5:30 pm Post subject:
The usual description should go more like a humming rather than a rumbling. Bad transformers may at times actually make a rattling noise. I guess you shouldn´t worry. Transformers are supposed to make some noise. THis is quite normal. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
sidx
Posted: Fri Jun 16, 2006 6:27 pm Post subject:
| oki thanx for info now im ok |
3phase
G2 patch files: 141
Posted: Fri Jun 16, 2006 7:33 pm Post subject:
| elektro80 wrote: | | Transformers are supposed to make some noise. THis is quite normal. |
actually they shouldnt...its rather a sign that the inbuild transformers are too tight dimensioned... If magnetic flux is the reason a round coil transformator would do the job..but they are much more expensiv than the standard modell used by clavia.
If a very sensetiv person really suffers from that noise it would be possible to get rid of it...
But in reality..this noise is much lower than the noise my computer makes... |
