Andromeda with untunable voices?
Page 1 of 1 [3 Posts]
lawst
PostPosted: Thu Oct 26, 2006 7:37 am    Post subject: Andromeda with untunable voices? Reply with quote  Mark this post and the followings unread
Just wanted to put a shout out to see if anyone else like myself and many others has recently purchased an Andromeda only to find that certain voices will not go in tune despite everything displaying as TUNEOK in the autotune menu. Mono patches are fine, but in poly mode various voices are severely out of tune. The out of tune voices change on each autotune or power cycle. When I first switched on the Andy I let the unit warm up for 20 mins and performed an autotune with unpleasing results. I tried soft and hard resets but a number of voices would still not go in tune. Tried autotuning some more times after the unit had been on for an hour but unfortunately with the same result. Seems like there may be a fault with the most recent units off the production line since there are others in the same boat...
sunny pedaal
Audio files: 12
PostPosted: Thu Oct 26, 2006 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
had the same problems 3 years ago .
congratualations at least your ers are fine
already more topics handle this subject so i suggest you first look in the list provided to see if help/info can be provided , otherwise we'll see what specific question can help
fr. gr. sunny
b.e. : http://electro-music.com/forum/topic-9929.html
sunny pedaal
Audio files: 12
PostPosted: Thu Oct 26, 2006 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
also on the moment , same subject being handled on:
a6@code404.com
( with same ol' tips like resettingthis, check the blue light, etc instead of: bring it to a service station and make use of your guarantee , afcourse!)
