 Forum index » Instruments and Equipment » MAX/MSP - Pd
Miller Puckett's fiddle object...
Page 1 of 1 [6 Posts]
flowersniffer7
PostPosted: Mon Nov 27, 2006 7:33 pm    Post subject: Miller Puckett's fiddle object... Reply with quote  Mark this post and the followings unread
Hey all...
I just finished a patch actually working on writting it into a vst, but basically it takes input data and analyzes the frequency... based on the frequency it will trigger one of 8 samples all with their own filters... then it speeds up or slows down the sample to match the pitch of the incoming signal... the Fiddle~ object in Max however seems to be a bit more shifty than it is in PD, anybody happen to know of a better, more accurate way to measure the frequency of an incoming signal in real time? It seems like a pretty complex process, especially some of the analysis processes I've seen and I am afraid it would over tax the CPU if I were to add anything else to this particular patch... Hmm... Anybody got any suggestions?
Chrishipgrave
PostPosted: Sat Dec 02, 2006 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi,
you could try analyzer~ or pitch~ but i've not used either so i don't know which is better. They are both based on the fiddle object.
Could you share the patch? I would be interested to see it.
Thanks
Chris
flowersniffer7
PostPosted: Sat Dec 02, 2006 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chrishipgrave wrote:
hi,
Thanks
Chris
its not fully completed... still some bug, but I will post it as soon as I finish the pluggo aplication.
analoguemind.zy8.org
flowersniffer7
PostPosted: Tue Dec 05, 2006 7:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
ehh... this is taking longer than I wanted and I don't have the time to finish it right now, so I'll post it as is with all the errors and bugs and what not... All I have to do is define the remainder of pluggo parameters... but I don't have the time to do it any time soon.
guitar sampler.pat
 Filename:  guitar sampler.pat
 Filesize:  31.84 KB
 Downloaded:  409 Time(s)
flowersniffer7
guitar sampler.pat
 Filesize:  31.84 KB
 Downloaded:  375 Time(s)
phasercs101
PostPosted: Sun Dec 10, 2006 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was using fiddle~ for one of my patches, trying to make my bass guitar into a MIDI sampler. I noticed fiddle's algorithms start to break down 330 HZ anything lower and the performance suffers. Thats my experience, pitch~ might work better but I haven't used that patch. Sorry if I can't be anymore help I just though I would give you my personal experience with fiddle~.
