compatybility
Page 1 of 1 [9 Posts]
softfreak
PostPosted: Wed Mar 15, 2006 11:26 am    Post subject: compatybility Reply with quote  Mark this post and the followings unread
as a total newbie in analog modular synthesis I am looking for
information concerning the compatibility of different systems.
as I know there are 5 and 6HE modules,
there are also differences in power distritbution...
with systems are compatible ?
maybe you can help me with a good link ?
I am especially thinking of some Motm or DotCom modules.
there are also interesting new german modules http://www.curetronic.de/curetronic/index-start.shtml
what do you think of http://www.modcan.com/page2.html modules ?
rob
edit. just found http://www.modularsynth.com/chart.html
but : do you have recommendations / tips concerning the
combination of different systems ?
softfreak
PostPosted: Thu Mar 16, 2006 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
actually,
I have just decided to start a nice little modular
based on Motm and DotCom modules.
Cool
Audio files: 227
PostPosted: Thu Mar 16, 2006 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
That chart is excellent. I would just make sure that all of the modules you choose have the same standard for CV and Gate/Trigger. 1V/Octave is pretty standard for the frequency CVs, but make sure the Gate/Triggers are the same. You can always convert from one kind of jack to another, but of course it is easier if you pick a standard for your modular rig and stick to it. I prefer 1/4" for audio - I haven't had much luck with minis. For controls, I like 1/4" or Bananas. All a matter of personal preference, of course.
FLechdrop
PostPosted: Fri Mar 17, 2006 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is another, more extensive, comparison chart: http://www.synthesizers.com/formfactors.html.
View user's profile Send private message Send e-mail MSN Messenger
ndkent
PostPosted: Sat Apr 08, 2006 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually I was thinking. Can one make a blanket statement that that in all modern (meaning since the 1990s) CV based equipment the CV & gate signals are compatible (and nothing insists on a separate trig signal anymore)?
I've got the feeling you almost can, though I'm sure some obscure combo out there that's an exception.
On the other hand if you are into 70s gear then the "standards" are far from standard.
PostPosted: Sat Apr 08, 2006 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not Buchla ... maybe not sure, but ... he does things ... differently ... ;!)
Audio files: 227
PostPosted: Sun Apr 09, 2006 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Even the Buchla stuff will work with the Moog style stuff to some extent. Buchla traditionally hasn't been intereted in conventional note-based music, so accurate oscillator and filter tracking hasn't been his focus. If you want to do a Switched On Bach type thing, some synths like the Buchla aren't going to be all that well suited. Still, they do play together.
morbius
PostPosted: Fri Jun 02, 2006 6:49 am    Post subject: Gate/triggers Reply with quote  Mark this post and the followings unread
Well.... actually... because of the type of 'open-ended' sequencer, the Moog 960, and Synthesizers.com Q960 do like the difference between a 'gate' ( a sustained pulse) and a 'trigger' (a short pulse similar to a sawtooth). With running analog step sequencers, side-by-side gate signals aren't usually seen as separate signals, but rather, one long signal. The trigger remedies this.
Initially, the dotcom Q960 was designed to work with gates, but very quickly, I showed Roger that it was nearly mandatory to be able to use triggers when it was desirable, so he came up with a modification to easily bring out the triggers. The triggers allow EG's and other modules which may need to see individual events or steps on the sequencer, actually see each step.
If you have another brand of step sequencer.... give this a try yourself, and see what happens. You need to be able to use 'individual' gates from each individual stage... NOT the master gate output. Each stage having it's own individual gate/trigger input and output is what allows the patching magic, which made the original Moog 960/962 so famous. Some newer sequencers may provide individual outputs... but you also need the trigger inputs to make full use of this giant among analog stepping sequencers.
~Morbius~
http://www.MusicByCybertron.com
morbius001a@yahoo.com
mikael_bonk
PostPosted: Sat Jun 03, 2006 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
There seems to be some difference in waveform levels between manufactourers (Or atleast from modcan) Or am i reading the information wrong ??
From Modcan : " Waveform Voltages: 0- 5V and +/- 2.5V peak-peak"
From Doepfer " Audio Signals are produced by the sound source Modules (such as VCO or NOISE), and lie in the range from -5 V to +5 V (10 VSS)"
From Blacet : "Standard +/-5V Waveform Levels"
From Motm : "Audio levels of 10V pk-pk"
But this only results in a weaker audiosignal, right ??
