Power from audio jacks
Page 1 of 1 [10 Posts]
nobody
PostPosted: Wed Jun 22, 2011 8:12 am    Post subject: Power from audio jacks
Subject description: How to do it?
Is it possible to draw power from 1/4" audio jacks? I'm thinking of building something and I need to be very economical about space and size.
The reason I'm even entertaining this thought is because this page says:
"The universal transmitter is powered by a built-in rechargeable battery; the 3G/4G iPod model is powered by the iPod’s remote/headphone jack, which means it reduces your iPod’s battery somewhat."
Would I have to wire things in a certain way to make this happen, or do audio jacks happen to pass along enough current to power a small device anyway?
loydb
PostPosted: Wed Jun 22, 2011 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
The examples I've seen are all wired specifically for power. Be sure you label that jack really, really well. Hideing
PostPosted: Wed Jun 22, 2011 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
The iThingies use a four pole connector; ground and stereo (headphones) out and then the 4th one for the mic - and that on has power.
Normal audio inputs never have a provision for power, some mic inputs do tho - as in walkman like recorders and stuff a low voltage for electret mic pre-amps, or the 48 V phantom power in mixers as used for condensor mics.
nobody
PostPosted: Wed Jun 22, 2011 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm, I guess I should rule that out as a power source, then. Thanks, guys.
egasimus
PostPosted: Wed Jun 22, 2011 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Standard audio jacks can be used for power, with a proper cable, of course. In theory, you can also transmit both audio and power over a single wire in the same way phantom power is implemented in mic preamps - have a decoupling capacitor at either end, take power from before it and signal after it. You won't be able to carry much current this way, though - 10-20 mA is the absolute maximum AFAIK. And I don't really know how you'll remove the signal from the power - I guess you're going to need some sort of high pass filter for that.
magman
PostPosted: Thu Jun 23, 2011 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Another point to note is that standard jacks get shorted as you insert the plug, so you have to have a PSU that can stand shorts for a small amount of time.
You can mitigate this to some extent if you use TRS (stereo) jacks and use the tip for the +ve voltage and screen for ground, but there is also the worst case scenario of a partially installed plug.
If you want to use bipolar supplies, look for another type of connector.
Regards
Magman
PostPosted: Thu Jun 23, 2011 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not use one of the small DIN connectors that are intended for this kind of use?
These are pretty small and not expensive.
Flickr
nobody
PostPosted: Thu Jun 23, 2011 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
What I was wondering is if any kind of power already exists in standard 1/4" jacks, which I now see is not the case.
But I have another idea for power. I want to build small devices that plug into, for example, the jacks on the back of my synths. These devices need power, so what if I create a wall outlet power adapter that plugs into the first such device, which plugs into the second device, which plugs into the third device, etc. I assume there would be a limit to the number of devices chained in this way, and that limit would depend on the power adapter. Would this work? Could I perhaps build a power adapter that, when turned on, first sends a small signal through the chain to determine how many devices are currently connected and uses a step transformer or something to regulate the voltage appropriately?
(Kind of talking out of my ass here, my university electronics courses were quite a while ago.)
PostPosted: Fri Jun 24, 2011 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Just choose a power supply that can supply more current than all the devices together need (say there are 5 devices that need 150mA each, then 5 * 150mA = 750mA or larger). No need to try & be "smart" about supplying just enough power.
If you used differential signals between those devices (on a mono signal) you can use the same setup as Phantom Power to send power along those lines.
nobody
PostPosted: Fri Jun 24, 2011 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right, that should work. Cool
