mtvic
Joined: Feb 03, 2003 Posts: 526 Location: Townbank Cape May NJ
Posted: Mon Feb 18, 2008 6:36 pm Post subject:
G2X Pitch Stick Weirdness |
Could the pitch stick on my G2 be out of calibration?
It does not track well i.e. ,wobbly pitching and takes some time for the sound to return to the played keys tone.
I have tried adjusting the bend amount to no avail.
Is there any hardware adjustments inside that could be made to correct this?
An adjustment screw perhaps? _________________ "I'm the transmitter' I give information."
>>> Kraftwerk Radioactivity<<< |
Joined: Apr 03, 2004 Posts: 24587 Location: The Netherlands, Enschede
Audio files: 309
Posted: Mon Feb 18, 2008 6:46 pm Post subject:
The pitch stick has a mechanical vulnerability ... it works with pressure sensitive resistors glued onto a bent piece of metal, sometimes they loosen up and that means they go weird, it also means repair is needed ... I fear you ran into that  _________________ Jan
mtvic
Posted: Tue Feb 19, 2008 8:44 pm Post subject:
Is there a way to reglue or repair without sending it in for repair, my warranty has expired. _________________ "I'm the transmitter' I give information."
ian-s
Audio files: 42
G2 patch files: 626
Posted: Wed Feb 20, 2008 2:09 am Post subject:
| I had my pitch stick replaced a couple of years ago. You could maybe get the part from Clavia and install it yourself. Only three wires to reconnect from memory. |
mtvic
Posted: Wed Feb 20, 2008 4:23 am Post subject:
Sounds like the right thing to do.
There is a Clavia authorized service center in the area,
maybe I can order from them and replace it myself. _________________ "I'm the transmitter' I give information."
mtvic
Posted: Wed Feb 20, 2008 6:08 pm Post subject:
Success g2x pitch stick weirdness |
mailed Jason At Nord US
here is the scoop
"From: "Jason Stanfield" <jason> Add Mobile Alert
To: "Michael Victor" <mtv022002>
Date: Wed, 20 Feb 2008 18:15:06 -0500
Subject: RE: Support From Michael Victor
They're $75, and yes I'll sell one to you direct.
Call me at [866] 855-2156 after 10am EDT and provide a credit card & shipping address.
Make sure to remind me of this email and that it's a pitch stick for a G2X … they're longer than the ones for the Leads
Jason Stanfield
Product Manager
Nord USA
jason@nordusa.com
[866] 855-2156"
info for future reference _________________ "I'm the transmitter' I give information."
ian-s
Audio files: 42
G2 patch files: 626
Posted: Wed Feb 20, 2008 9:25 pm Post subject:
Re: Success g2x pitch stick weirdness |
| mtvic wrote: | mailed Jason At Nord US
here is the scoop
That's good news I guess.
I had mine replaced by a serviceman back in 2005ish and was only charged 30NZD all up(=15USD in those days)
Maybe I got a good price because it was only a few months out of warranty.
Off topic, I bought an expensive (2-3K) swivel chair 5 and a half years ago. Recently, one of the arm rests developed a small split which my three year old Liam, happily picked at till he exposed the sharp metal sub structure.
I took the arm off and walked down to the store I bought the chair from to see if I could get a replacement. The shop had moved to new premises across the road. I had no proof of purchase and they had no record of me on computer but the salesman called the agent. He then offered to courier a complete new pair of arms to my address, at no cost
The arms arrived but wouldn't fit because they were for a newer model. I managed to unscrew the arm rest parts and the chair is as good as new. |
mtvic
Posted: Thu Feb 21, 2008 4:31 am Post subject:
I have received some knobs that had come off my DSI Desktop evolver.
Just dropped an e-mail to Dave explaining the design flaw of the knobs being loose and falling off .
He sent me a set free of charge.
Then again;same situation with my novation xio synth.
Novation came through with some free replacements even during
NAMM show 2008!
And again from Jason for my nord lead 2X ,
when it slid from my X stand and broke off a key he came through for me with a free replacement .
I guess mechanical parts like the pitch stick assembly for the G2 are not
free but,75 dollars isn't an unreasonable price for such a part.
One thing is for sure, Clavia US has quick response for technical issues.
Once again,
thanks for your help Ian and Jan,
You gotta love electro-music.com
mtvic
Posted: Fri Feb 22, 2008 4:32 am Post subject:
A replacement is on its way!!!
I am thankful for all of your assistance.
I will post again when it arrives.
In case I need assistance with the installation
m _________________ "I'm the transmitter' I give information."
mtvic
Posted: Thu Feb 28, 2008 10:06 am Post subject:
Replacement has arrived .
Now its time to crack open the g2x and get the iron hot .
Installation should be simple .
If any problems arise I'll be sure to consult.
mtvic
Posted: Mon Mar 10, 2008 5:54 pm Post subject:
Operation Pitch stick
Completed without an iron
Open
Cut
Splice Wires X 8 (2 RED ,2 BLUE X 2
add new part (Pitch Stick)
Crimp on disconnects X 4
Connect disconnects
CLOSE
PLAY
SUCCESS _________________ "I'm the transmitter' I give information."
Audio files: 309
Posted: Mon Mar 10, 2008 6:41 pm Post subject:
onosendai
G2 patch files: 4
Posted: Sat Nov 06, 2010 1:02 pm Post subject:
I have to replace mine.
How do you open a G2 ? I've tried to remove all the up screw but i can't open it. Bottom screw ? |
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Sat Nov 06, 2010 5:51 pm Post subject:
| onosendai wrote: | I have to replace mine.
Yes, there are also some screws on the bottom of the case that need to be removed, but there are many screws that do not. The instructions for installing the expansion board tell what needs to be done to properly open the case:
http://www.clavia.se/G2/V1_10/G2expansionboard.pdf
Good luck with your repair! _________________ varice |
onosendai
G2 patch files: 4
Posted: Sat Nov 06, 2010 6:27 pm Post subject:
Done ! Thanks
But i have new questions
Open <-- Check !!
Cut <-- Cut what ? Pitch Stick wire ?
Splice Wires X 8 (2 RED ,2 BLUE X 2 <-- What does that mean ?
add new part (Pitch Stick) <-- I see
Crimp on disconnects X 4 <-- What does that mean ?
Connect disconnects <-- What ?
CLOSE <-- easy
PLAY <-- ahah too easy
SUCCESS <-- it will be nice |
Nodular
G2 patch files: 7
Posted: Thu Jul 21, 2011 7:42 am Post subject:
Hello,
this is strange.
Pitch Stick weirdness started gradually on my G2X.
After a 2 months period the stick was working really bad so I ordered a couple of replacements.
They arrived quickly and I immediately replaced the faulty stick with a new one.
SURPRISE !!!
The problem is still there, even if a minimal improvement can be noticed.
Any idea of what could have happened anybody ?
boxcolony
Nodular
G2 patch files: 7
Posted: Mon Nov 25, 2013 6:15 am Post subject:
| Nodular wrote: |
SURPRISE !!!
Well... this is strange. I'm returning with an odd fact. Gradually, slowly, but relentlessly, my repaired pitch stick, became more and more stable until now that it's working flawlessly every-time I turn up the synth.  |
Audio files: 309
Posted: Mon Nov 25, 2013 8:25 am Post subject:
You didn't give the G2 any booze did you? _________________ Jan
Nodular
G2 patch files: 7
Posted: Mon Dec 02, 2013 7:18 am Post subject:
nope
And maybe that's why the mic input is really dead on my G2X. I should have been more indulgent with booze.  |
