Resetting the ClkGen
Page 1 of 1 [4 Posts]
sebber
G2 patch files: 33
PostPosted: Wed Feb 22, 2006 1:20 pm    Post subject: Resetting the ClkGen
Subject description: Is there something wrong in Den..., ahm, Sweden?
Is this a bug? The ClkGen reset doesn't work properly here.
It "fails best" if the first ClkGen sends out a signal every 16th beat to reset both ClkGens. Then we have a glitch every 96th beat.
If it doesn't work immediately, try turning on/off the first ClkGen. It might show up immediately or take some time. Unfortunately it's not something that's always there.
If you take something else than a ClkGen to reset, like a LFO that resets itself a ClkGen it's much worse. In the attached patch it's a very small glitch, but it grows in bigger settings.
The attached patch was done with the demo of 1.40 on an XP system. I can't try it on a "real" maching now, but the patch where I noticed it didn't work on a G2, so I guess it'll be the same.
ClkBug.pch2
Supposed bug while resetting the ClkGen
 Filename:  ClkBug.pch2
 Filesize:  1002 Bytes
 Downloaded:  1455 Time(s)
Fish don't swim. They dive.
Audio files: 229
PostPosted: Wed Feb 22, 2006 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it does that here on my G2X. Crying or Very sad
Audio files: 299
PostPosted: Wed Feb 22, 2006 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes it glitches. I tried setting the clock gens to master mode as well, when both are in master mode I hear no glitches, but when one or both are not in master mode its present.
sebber
G2 patch files: 33
PostPosted: Wed Feb 22, 2006 7:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for checking. I sent it to Clavia, or rather: I sent them a link Laughing
Yup, and my Metronome-patch would work if this would. So the waiting starts again - where's v1.41?
