ian-s
Audio files: 42
G2 patch files: 626
Posted: Fri Apr 13, 2007 10:33 pm Post subject:
| Blue Hell wrote: | | In the above patch there seems to be something odd with the zwolle scale |
I think it is ok, the sign bit (gate signal) on the coarse tune seq is the opposite to what you might expect.
#1, The first pair of fine/coarse is always zero.
#2, is flat from the ET semitone of 100 cents, so the coarse offsets the frequency by -100 cents, then the fine tune is set to 97 int(128/100 * 76.049)
#4 is sharp from ET of 300 by only 3 cents so zero on coarse, and 3 on fine???
If I used Swiss rounding, that would be 4 which is closer to 3.84. An error of -0.16 is better than +0.84 of a cent.
Sorry about the less that ideal sign implementation, +-6400 cents wasn't enough for the extreme scales.
Beautiful prf by the way, sounds like Blue Hell from a parallel universe. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Apr 14, 2007 12:40 am Post subject:
| Updated the zip with the new rounding on fractional cents. |
and70it
Posted: Mon Apr 16, 2007 12:47 pm Post subject:
| GovernorSilver wrote: | Ok, I got scalaG2.py to generate .pch2 files on my Powermac G4. As a recap, here are the instructions I followed:
1. Go to http://www.python.org/download/ and download Python for Mac OSX. I got 2.5
2. Run the Python installer
3. Download and unzip g2ools.zip
4. Download and unzip the scalaG2.zip. Unfortunately, Stuffit Expander (the Mac equivalent of WinZip) does not let you choose unzip a .zip file on top of an existing folder like WinZip does. So....
5. Manually copy scalaG2.py and G2SCL.pch2 into the g2ools folder. BOTH are needed, otherwise you'll get errors. The first time I tried to run the .py, I got an error because it couldn't find the nord folder, so you MUST copy it to the root folder of g2ools.
6. Start the Terminal app to get Mac OSX's command line prompt, cd to the g2ools folder (I put it in Applications, so it took me a while to figure out where it was in the file system).
7. Here is Ian's instruction to use the tool after all of the above (I paste them here from the older thread):
At the command prompt, type:
scalaG2.py scalafile1.scl scalafile2.scl ...
A pch2 file for each scala file is produced.
My comment: On Mac OSX add the ./, so it should be:
./scalaG2.py scalafile1.scl
Otherwise, you'll get a command-not-found type error
I tried some 12-out of XX tunings but couldn't tell if they worked because they sound so close to standard 12TET. Then I had the tool generate from the 79 out of 159TET patch - the .pch2 file that was created had a much more dramatic effect.
So far, so good. I'll do some more .pch2 file generation testing tonight. I continue to be excited...  |
Help i dont understand the Instructions and this is what my Terminal say
HELP
 Download (listen) |
| Filename: |
Immagine 4.pdf |
10.58 KB |
| Downloaded: |
1277 Time(s) |
Joined: Apr 03, 2004 Posts: 24513 Location: The Netherlands, Enschede
Posted: Mon Apr 16, 2007 1:02 pm Post subject:
The name "scalafile1.scl" is a symbolic name to be replaced by the name of an actual and existing scala (.scl) file.
You can download scala files for a lot of different tunings from the the scala site, there is a link in the 2nd post on this thread. Or you can make your own scala files for your own tunings, this is explained on the scala site as well. _________________ Jan
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Posted: Tue Apr 17, 2007 2:02 pm Post subject:
| and70it wrote: | | GovernorSilver wrote: | Ok, I got scalaG2.py to generate .pch2 files on my Powermac G4. As a recap, here are the instructions I followed:
HELP |
and70it,
If you have a specific question, I'll try to help. How far did you get from Step 1 to Step 7 in the instructions I provided? |
GovernorSilver
Posted: Tue Apr 17, 2007 2:14 pm Post subject:
Sorry guys, I've fallen behind in helping out in the testing effort.
Was the .kbm (Scala Keyboard Mapping file) support implemented, since it promises to simplify the job of mapping a tuning to the G2 keyboard (ie. you don't have to guess at what mapping the user will want - just use the mapping in the .kbm file)?
I did get clarification from Manuel Op De Coul on the difference between Middle Note and Reference Note in the .kbm format spec. As a recap, the sample template:
! Template for a keyboard mapping
! Size of map (greater than or equal to the number of notes in the scale
! to be mapped). The pattern repeats every so many keys:
12
! First MIDI note number to retune:
0
! Last MIDI note number to retune:
127
! Middle note where scale degree 0 is mapped to:
60
! Reference note for which frequency is given:
69
! Frequency to tune the above note to (floating point e.g. 440.0):
440.0
! Scale degree to consider as formal octave (determines difference in pitch
! between adjacent mapping patterns):
12
! Mapping.
! The numbers represent scale degrees mapped to keys. The first degree is for
! the given middle note, the next for subsequent higher keys.
! For an unmapped key, put in an "x". At the end, unmapped keys may be left out.
0
1
2
3
4
5
6
7
8
9
10
11
Explanation:
- First and Last MIDI Note To Retune look self-explanatory
- Middle Note = MIDI Note Number which will be the 0th degree of the scale. In the above sample template, MIDI Note Number 60 is the 0th degree. So Note Number 61 = 1st degree, Note Number 62 = 2nd degree, etc.
- Reference Note = The MIDI Note Number to which the absolute frequency (in Hz, not cents) will be applied. In the above example, that would be MIDI Note Number 69 (typically mapped to A above middle C). All other MIDI Note Numbers are thus offset from Reference Note by the frequency ratios or cents specified in the .scl file.
- Reference Frequency = The absolute frequency of Reference Note above. In the above example, MIDI Note Number 69 is to be tuned to 440Hz.
Once again, my apologies for potentially causing extra/unnecessary work by my tardiness. I downloaded the full Scala application zip file so I can provide some sample .kbm files that are intended for specific .scl files. |
and70it
Posted: Wed Apr 18, 2007 7:53 am Post subject:
ok |
I have forgotten to place the scales in the g2ools folder.
A question where can i find theoric info about the different scales?
I have no music background.
thanks
Andrea |
GovernorSilver
seraph
Editor
Audio files: 33
GovernorSilver
Posted: Thu Apr 19, 2007 2:53 pm Post subject:
I recorded myself playing a blues jam on the G2X keyboard... very, very badly... with, I think the Blackjack tuning a couple of weeks ago.
I figure the Blackjack tuning and keyboard mappings would be good test for the tool - more than 12 notes in an octave, but not an excessive amount like 96TET, and more easy to see if indeed the mapping was properly done. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Thu Apr 19, 2007 4:07 pm Post subject:
| GovernorSilver wrote: | Was the .kbm (Scala Keyboard Mapping file) support implemented, since it promises to simplify the job of mapping a tuning to the G2 keyboard (ie. you don't have to guess at what mapping the user will want - just use the mapping in the .kbm file)?
The kbm file is simple but quite comprehensive, many possibilities. It would add quite some complexity to the application I think.
The two controls in the building block (Transpose and the LevAdd2 next to it) allow for tuning the base frequency and offsetting the midi note number respectively.
I guess if I ignored the non-linear remapping possibilities, I could set those two controls automatically. |
GovernorSilver
Posted: Fri May 11, 2007 2:20 pm Post subject:
| Progress on the microtonal front has been slowed for me, but I may be getting my hands on a guitar designed for Robin Perry's "Roz" tuning, with all 27 notes of the tuning. Robin was kind enough to send me the .scl and .kbm files for this tuning as well, so when I do get around to it, I'll see what I can do to set up the G2 with this tuning, so i can use the G2 in conjunction with the new guitar. |
seraph
Editor
Audio files: 33
Posted: Fri May 11, 2007 3:23 pm Post subject:
| GovernorSilver wrote: | | ..."Roz" tuning, with all 27 notes of the tuning... |
what kind of tuning is that  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
GovernorSilver
Posted: Tue May 15, 2007 1:18 pm Post subject:
The Roz Tuning was invented by Robin Perry and is an approximation (very close to 200-EDO) of Just Intonation for guitar, such that straight frets may be utilized and spaced widely enough to be comfortable to play. He is having an experimental guitar built by Austrialian inventor Dave Keenan with this tuning. I think he can explain his tuning better than myself, but that's my understanding.
I believe this is the Just tuning that is being approximated:
! C:\Program Files\Scala22\JINTO1.scl
HARMONIC AND SUBHARMONIC SEVEN LIMIT
12
21/20
10/9
7/6
5/4
4/3
10/7
3/2
100/63
5/3
7/4
40/21
2/1
Here is the full 27-note Roz tuning:
! C:\Program Files\Scala22\FRETBOARD.scl
FRETBOARD
27
66.00000
90.00000
114.00000
180.00000
204.00000
270.00000
294.00000
318.00000
384.00000
408.00000
474.00000
498.00000
588.00000
612.00000
678.00000
702.00000
768.00000
792.00000
816.00000
882.00000
906.00000
972.00000
996.00000
1086.00000
1110.00000
1176.00000
1200.00000
He also provided this 7-note subset of the tuning:
! C:\Program Files\Scala22\roztuning.scl
FRETBOARD
7
498.00000
882.00000
1200.00000
1470.00000
1788.00000
2172.00000
2670.00000
And a .kbm file (very nice of him!):
! Size of map:
0
0
127
49
49
261.625565
! Scale degree to consider as formal octave:
0
! Mapping. |
holeps
Posted: Sat Dec 29, 2007 2:48 pm Post subject:
problem downloading the scalag2 file |
Hello everybody,
I am trying to download the scalag2 zip archive and it doesn't work. Any suggestions? I am a begginer. I just got a Nord G2 and I would really like to experiment with some tunnings as this will be a project for my master thesis.
Thanx. |
Posted: Sat Dec 29, 2007 2:53 pm Post subject:
holeps,
the zip is not present indeed, it got lost probably in the great server crash we had in august. I hope Ian will re-up it. Otherwise I might have a copy somewhere still, as I've used the tool a few times. So please complain when nothing happens  _________________ Jan
holeps
Posted: Sat Dec 29, 2007 2:59 pm Post subject:
| Thank you very much for your immediate response. I hope that someone will upload this tool. It will be really useful for me. I would also like to say thank you for keeping alive this incredible site. |
cappy2112
Joined: Dec 24, 2004 Posts: 2500 Location: San Jose, California
Posted: Sat Dec 29, 2007 3:07 pm Post subject:
Re: ScalaG2 Subject description: read scala tuning files and set G2 tuning |
| g2ian wrote: |
Updated 6 April: 96 tone
14 April: Swiss rounding of fractional cents  |
Are these 'cents' based on the Euro or Dollar?
You know, the conversion rate is just going to wreak havoc
with the pitch  |
Posted: Sat Dec 29, 2007 3:20 pm Post subject:
Ok, I found an old version, I'll attach that one here and remove it once someone posts a more recent one.
Tony your Humor is twisted at times
Edit: attachment deleted, the original was rebeamed by Ian. _________________ Jan
cappy2112
Posted: Sat Dec 29, 2007 4:03 pm Post subject:
| Blue Hell wrote: | Ok, I found an old version, I'll attach that one here and remove it once someone posts a more recent one.
Tony your Humor is twisted at times  |
If you knew me better Jan, you would know my humor is always twisted
(It's just that I have limited time to make that known)
Thanks for upping the file. This scal tool is something I wasn't aware of. |
holeps
Posted: Sat Dec 29, 2007 4:19 pm Post subject:
| Thank you very much about this. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat Dec 29, 2007 5:04 pm Post subject:
Latest zip uploaded again so link in first post should work.
I think someone posted a G2 bug report regarding adjacent sliders on the value sequencer interacting.
I haven't checked to see what, if any, effect this has on the tool. |
Posted: Sat Dec 29, 2007 5:22 pm Post subject:
Thanks Ian, I saved a copy this time ... wish I had a time stretcher to do more with interesting stuff like this ...
I think Tim posted the bug report ... let me see ... it's not in the bugs section .. there is a related item about the xfader being off by Tim : http://electro-music.com/forum/topic-6980.html ... all I could find
I seem to remember there is an issue though. _________________ Jan
