 Forum index » How-tos » Micro Tuning
Microtuning and Clavia G2
Page 1 of 1 [10 Posts]
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Apr 05, 2007 1:15 pm    Post subject: Microtuning and Clavia G2 Reply with quote  Mark this post and the followings unread
Converting Scala files to run in the G2 arrow http://electro-music.com/forum/topic-17192.html
Patch to micro tune the G2 arrow http://electro-music.com/forum/topic-10387.html
G2 wish list - micro tuning arrow http://electro-music.com/forum/topic-3235.html
More about alternative tunings with the G2 arrow http://electro-music.com/forum/topic-2529.html
[editor's note: added explanations on the links. --mosc]
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Mar 07, 2008 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
btw I've used the G2 coupled with LMSO application for microtonal purposes already. Check this out.
GovernorSilver
PostPosted: Mon Mar 10, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work!
Are you using LMSO to microtune the G2 via pitch bend? I still feel kinda flaky for holding off on the Scala converter project.
Some old stuff on VIRB
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Mar 10, 2008 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
exactly
GovernorSilver
PostPosted: Tue Mar 11, 2008 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Grazie, Seraph!
I might end up doing that too. Learning Python, then refactoring the code to produce only the tuning component (so you're not stuck with electric piano all the time), and implementing .kbm file support is beyond my ability at the moment (lack of time).
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 11, 2008 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
it is beyond my ability too. period Exclamation
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Mar 11, 2008 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
The python code only deals with the modules in the tuning section of the patch, and ignores any other modules. Just delete the dxpiano modules from G2SCL.PCH2 and paste in whatever synth you want for a new template.
You only need to keep the Keyboard1 module, and connect the output of mix1-1A1 to all the oscillators in the new synth.
The bug I though compromised the tuning I tested just now. I can't perceive any pitch change at all from the fader leakage, even when multiplying the error by 16 and using the full fader range.
How does LMSO get around having pitch bend common to all the voices in a polyphonic patch? Do you need to run a mono version of the patch in all four slots?
seraph
Editor
Editor
Audio files: 33
PostPosted: Tue Mar 11, 2008 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes, 4 notes polyphony means 4 monophonic patches each on a different midi channel to be able to retune each one independently.
GovernorSilver
PostPosted: Thu Mar 27, 2008 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I just wanted to say big respect to both Ian and XJ for their hard work on their respective software.
I still intend to get my LMSO updated and I still intend to learn Python (I'm a Java programmer) and actually contribute something to the G2 tools effort.
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Mar 27, 2008 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
absolutely Exclamation
