fky
Posted: Thu Dec 06, 2007 9:14 am Post subject:
Waldorf Blofeld!!! |
Blofeld is really released now. It seems it can be shipped wroldwide though the below distributor from German
http://www.touched-by-sound.com/
I am going to buy one, any one have other idea about this module? _________________ http://soundcloud.com/fkyfkyfky |
cappy2112
Joined: Dec 24, 2004 Posts: 2500 Location: San Jose, California
zoonewbie
Posted: Tue Dec 18, 2007 2:57 am Post subject:
I have pre ordered and I am getting increasingly excited!!!
Thomann have changed the availability to "a few days" so it could possibly be on my doorstep this week!?
Thomann is german right!? so I guess potentially I could be one of the first people to get this synth? "haa haa"
anyway, I think this synth is what I have been waiting for, as I have been debating getting a Q or similar for ages and then this comes out of the blue just as I have some dosh! yippee! I have been after a new synth for ages and really wanted one with loads of knobs etc but i guess I can control the blofeld with a BCR thingy so should all be good.
sorry, just a little excited. |
zoonewbie
Posted: Wed Dec 19, 2007 4:37 am Post subject:
totally jinxed it with^^^that post!
Availability has changed to "shipment due to arrive on 24/12/07" doh! |
zoonewbie
Posted: Mon Feb 18, 2008 9:16 am Post subject:
I have had this little beast for about 2 weeks now.... it seems I was one of the first oversees customers to get one as alot of people are still waiting!?
Right, there are a few niggles with this machine, i.e. random volumes for presets, low output volume... which will probably sorted in the next OS, but are not major problems really.
anyway, it really is a beast! sound is typical Waldorf with all XT wavetables and Q presets, great filter section with comb, PPG etc, The effects are a ton better than I thought esspecially the drive/distortion.... You can be all smooth and creamy and with a couple of twiddles its hard, dirty and very nasty!
The amount of routing possibilities makes plenty of scope for much weirdness.
A perfect (cheap) addition to anyone who likes a bit of strange synth in their setup. Thumbs up from me.
Editor's note: Please, do not double post - seraph |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Wed Mar 19, 2008 8:44 am Post subject:
I have heard there were some bugs in the initial version. But there is a downloadable version 1.02 - does this fix the major bugs?
Also, can anyone tell me if I will be able to replace my Microwave XT with one of these? Any differences in sound, or missing features (other than the number of knobs)? _________________ www.gregwaltzer.com |
Posted: Wed Mar 19, 2008 9:20 am Post subject:
I dunno.. it kinda is all ( or almost all ) previous Waldorfs. I found some excellent PPG stuff in there as well. It seems to well built. The interface is a bit like the microrackthingies.
Obviously what you are lacking here is the sub out pair that the XT has. The Blofeld has a single stereo output. Considering the price this is not really a problem. You only need to buy more Blofelds: Problem solved.
My verdict so far is that the Blofeld is briliant. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
davep
Joined: Jul 05, 2004 Posts: 467 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Thu Mar 20, 2008 3:09 pm Post subject:
| zoomtheline wrote: | | I have had this little beast for about 2 weeks now.... |
Hi Zoomtheline,
I have a question about the midi connections on the Blofeld. The Waldorf site says that the Blofeld does not have standard 5-pin midi DIN connectors, it has a USB connector for midi instead. That may be OK if you only have one or two synths and you want to connect the Blofeld directly to a USB port on your computer, but how the heck would you connect this synth to a multi-synth midi system? For example, I use a large 8-port MIDI patchbay / router in my synth rig and I would need some way to connect the Blofeld to this type of equipment that has standard 5-pin midi DIN connectors, not USB conectors.
I've looked around for a simple USB-to-MIDI adapter, but all of them are the opposite of what the Blofeld needs. They are all USB "A" connectors to midi, not USB "B" connectors (so the USB end is for connecting to your computer, not for connecting to external devices like the Blofeld). Any suggestions? _________________ Dave Peck |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Thu Mar 20, 2008 3:29 pm Post subject:
| davep wrote: | | The Waldorf site says that the Blofeld does not have standard 5-pin midi DIN connectors, it has a USB connector for midi instead. ... |
What I read on the whale village site and have 'heard' elsewhere on the net is that it has a midi-in (no out/thru) din connector + usb for midi in and out. No problems with good old-fashioned midi cables, as long as you have it on the end of your chain. _________________ Spinning at ~0.0000115740740741 Hz |
Posted: Thu Mar 20, 2008 3:30 pm Post subject:
Sorry Dave,
For any device to talk over MIDI, it's going to need a driver that understands how the device enumerates, and thus how to configure the device. That, typically, means an OS like Windows, Linux, or MAC. It's possible to make an embedded controller that can might talk to the blofeld, but you'd probably need someone that can decode the USB protocol it uses, or get that info direct from Waldorf.
I'd guess you're easiest/only option is to use a computer to route between various USB attached devices, and a (USB attached?) MIDI Router (using MIDIOX or similar). Maybe a nanoITX board? USB, by the way, can support up to 256 devices attached to it, and USB 1.1 probably has enough bandwidth to support 256 MIDI ports (12MHz / 31.25kHz >= 256).
-jk* |
Posted: Thu Mar 20, 2008 3:34 pm Post subject:
There is a midi in port. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
kvnvk
Posted: Thu Mar 20, 2008 5:25 pm Post subject:
| yep, a single MIDI in port and that's it. just picked up a used Blofeld for a good price and I've been playing around with it for the last couple of days. I was really surprised at how easy it was to figure out the user interface, only had to crack the quick start guide and scan through it and I was jumping and scrolling through all the parameters in no time. the sound of the Blofeld does remind me quite a bit of the Microwave XT I had a few years ago. |
zoonewbie
Posted: Thu Mar 27, 2008 5:52 am Post subject:
Hello, yes the blofeld has a typical midi in only and also the usb (which I have only used to download the upgrades OS)
All of my gripes about this machine have been corrected by the new update,
especially the crashing which was getting a tad annoying!
since the update my love for the blofeld has grown. It continues to suprise me everytime I start tweaking with it.
Its a banging little synth! especially for the money! |
Posted: Thu Mar 27, 2008 6:59 am Post subject:
Doesn´t the paint job thingie around the display tend to peel off just by looking at it? It kinda looks a bit daft.. someone else have this problem? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
zoonewbie
Posted: Thu Mar 27, 2008 9:22 am Post subject:
erm, no sorry!
I did actually drop it on a concrete floor the other day and expected to see alot of chips etc............ but it was pristine! ha
I do have a sticky knob though! fnar |
Posted: Thu Mar 27, 2008 5:52 pm Post subject:
Hmm... perhaps I have a dud here. I´ll kick some ass and get a fresh one. Either that or I´ll have to spray with some of that mid 80s salmon beige paint.
Anyways, the Blofeld is seriously good. Salmon beige feels wrong though. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
kvnvk
Posted: Fri Mar 28, 2008 3:12 am Post subject:
no peeling paint on mine either, but now you have me worried.  |
fky
Posted: Wed Apr 09, 2008 9:15 pm Post subject:
I post this topic several month ago. However, due to some oversea shipping problem in China, I finally choose a second hand Waldorf Micro Q and ordered a New Nord G2 from local Clavia distributor in China.
Would someone please tell me what is the difference between the sounds of micro-q and Blofeld, It seems like the sounds and synth theroy from Blofeld is quite similar to the VST Komplexer.Very glassy and digital cold! It that real?
probably I will get on in the late of this year for my live stuffs in the future. _________________ http://soundcloud.com/fkyfkyfky |
rh2y
Joined: May 08, 2007 Posts: 218 Location: Pittsburgh, USA
Posted: Mon Apr 14, 2008 4:32 pm Post subject:
-No recordings yet that make any sense since the stuff I´ve done so far are only parts of much larger stuff. I rehearse bits and parts and sections to click tracks and try to make sense of the piece as a whole.
Anyways, I returned the Blofeld. They´ll send me a new one. For some reason something was seriously wrong with the paint job. Right now I´m busy patching on the dotcom and the Ion. I shouldn´t though. What I really should be doing is building two portable cabinets ASAP. The dotcom 22 unit wide cabinet form factor is a bit to large for me.. and the 11 unit wide portable dotcoms are too small. I haven´t decided yet on a width of 12 or 14 units. Two rows of 14 units in each portable cab seems reasonable to me. I should probably build three because I need to a place for the two Klees and all the other DIY stuff.
I guess I´ll throw in some multis at the bottom of the cabs and a slot for a lexicon multieffect or something of the sort. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
kvnvk
Posted: Tue Apr 15, 2008 4:44 pm Post subject:
| that paint peeling issue was kind of odd, guess maybe the particular unit you had wasn't prepped properly before being painted. |
Posted: Tue Apr 15, 2008 4:58 pm Post subject:
I guess you are right. Anyways, it will be sorted out. I want my Blofeld back. Or rather, I´ll be getting a new one. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
fac
Posted: Wed Apr 16, 2008 5:58 pm Post subject:
| elektro80 wrote: | The dotcom 22 unit wide cabinet form factor is a bit to large for me.. and the 11 unit wide portable dotcoms are too small. I haven´t decided yet on a width of 12 or 14 units. Two rows of 14 units in each portable cab seems reasonable to me. I should probably build three because I need to a place for the two Klees and all the other DIY stuff.
Another option is to use the 8-space rack frames to build a 16-space wide cabinet. |
Posted: Wed Apr 16, 2008 6:29 pm Post subject:
I actually considered that. I guess I simply like building stuff.  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
