yusynth
Posted: Mon Feb 25, 2008 5:36 am Post subject:
New yutility module |
Here is a new YUSYNTH utility module.
It is a dual COMPARATOR module to create GATE signal and pulses from another source of signal. It can be used either to process modulation CVs or audio signal (though it's not a GATE extractor as it can be found with envelope followers).
Enjoy it at :
http://yusynth.net/Modular/EN/COMPARATORS/index.html
Description: |
Filesize: |
4.1 KB |
Viewed: |
9662 Time(s) |
Description: |
Filesize: |
18.95 KB |
Viewed: |
9663 Time(s) |
_________________ Yves |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
bugbrand
Posted: Mon Feb 25, 2008 6:37 am Post subject:
Looks great Yves! A really useful module, very nicely presented. And don't think I've seen an Off Trig before - seems like a great addition. Dual modules always rule, too (two.!.) _________________ http://www.bugbrand.co.uk
RF
Audio files: 28
Posted: Mon Feb 25, 2008 7:20 am Post subject:
Thanks for this! Very nice. |
frijitz
Audio files: 54
Posted: Mon Feb 25, 2008 8:46 am Post subject:
Ooooooops. Sorry! That was intended as a PM.  Last edited by frijitz on Mon Feb 25, 2008 8:58 am; edited 1 time in total |
yusynth
Posted: Mon Feb 25, 2008 8:53 am Post subject:
what is TGTSH ?
EDIT : OK Ian, I've just checked your site and found the TGTSH, and yes they have some common functionalities threshold, GATE and onset trig. _________________ Yves |
frijitz
Audio files: 54
Posted: Mon Feb 25, 2008 9:06 am Post subject:
That's a nice circuit, Yves. From feedback I've gotten, the end trigger is a feature that many will find useful.
Ian |
neandrewthal
Posted: Mon Feb 25, 2008 10:20 am Post subject:
Very nice. Just curious, what would it sound like if you ran it audio frequencies?(if this is even possible). Some kind of wacky, pitch shifting PWM? _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
yusynth
Posted: Mon Feb 25, 2008 10:34 am Post subject:
Well if you use the GATE OUT only it will sound just like PWM. Now if you combine the three outputs with an inverting/direct mixer and tweak the polarization (invert sign or direct) of the various signals I guess (I haven't tried it yet) you would obtain a mixture between PWM and SYNC effects. I'll give it a try... _________________ Yves |
yusynth
Posted: Mon Feb 25, 2008 10:49 am Post subject:
Used as a controller one may imagine interesting patches such as feeding
the input with white or pink noise, and feeding the ON TRIG pulse to a Band-pass VCF set to high resonance and modulated by some LFO or wandering CV, and sending the OFF TRIG pulse to another Band-pass VCF set to high resonance and modulated by another LFO. This way one gets two independant alternating dropping water stereo sounds.
Or feeding the INPUT with a slow random CV and using the ON TRIG to clock a step sequencer,and the OFF TRIG to clock a second step sequencer. This way one would get two random clocked intermangling sequences. _________________ Yves |
