 Forum index » Artists » Static Strobe Emitter
8-Bit NES Chipmusic
Post new topic   Reply to topic Moderators: Static Strobe Emitter
Page 1 of 1 [14 Posts]
Audio files: 243
PostPosted: Mon Mar 03, 2008 7:29 am    Post subject:  8-Bit NES Chipmusic
Subject description: Let the chips be with you!
This was a pretty popular console back in the 1980s.
For those unfamiliar with what it is can go into this wikipedia link
http://en.wikipedia.org/wiki/Nintendo_Entertainment_System
The soundchip specs are (directly from wikipedia):
The NES board supported a total of five sound channels. These included two pulse wave channels of variable duty cycle (12.5%, 25%, 50%, and 75%), with a volume control of sixteen levels, and hardware pitch bending supporting frequencies ranging from 54 Hz to 28 kHz. Additional channels included one fixed-volume triangle wave channel supporting frequencies from 27 Hz to 56 kHz, one sixteen-volume level white noise channel supporting two modes (by adjusting inputs on a linear feedback shift register) at sixteen preprogrammed frequencies, and one delta pulse-width modulation channel with six bits of range, using 1-bit delta encoding at sixteen preprogrammed sample rates from 4.2 kHz to 33.5 kHz. This final channel was also capable of playing standard pulse-code modulation (PCM) sound by writing individual 7-bit values at timed intervals.
I will convert all tracks to MP3 for easiest playback.
However if i gets asked to give away a source to be compiled code for
replaying on a real NES hardware i can provide that for each individual track.
Cheers!
Audio files: 243
PostPosted: Mon Mar 03, 2008 7:37 am    Post subject: Mystery Roses of Affinity
Subject description: NES
hello =)
strobe-mysteryrosesofaffinity.mp3
blips'n blops!
 Filename:  strobe-mysteryrosesofaffinity.mp3
 Filesize:  4.76 MB
 Downloaded:  4170 Time(s)
Audio files: 243
PostPosted: Mon Mar 03, 2008 7:43 am    Post subject: Tantalum Molly Reply with quote  Mark this post and the followings unread
waffles?
strobe-tantalummolly.mp3
more blips n' blops =o
 Filename:  strobe-tantalummolly.mp3
 Filesize:  5.35 MB
 Downloaded:  4303 Time(s)
Audio files: 308
PostPosted: Mon Mar 03, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aah .. I had been missing that ... good to hear that the music still works Cool
Audio files: 243
PostPosted: Mon Mar 03, 2008 7:25 pm    Post subject: What orbits around my head? Reply with quote  Mark this post and the followings unread
=o
strobe-whatorbitsaroundmyhead.mp3
Seamless Dutycycle tricks, Massive DPCM abusing at the end.
Thanks to JSR for bankswitching capabilities!
 Filename:  strobe-whatorbitsaroundmyhead.mp3
 Filesize:  6.07 MB
 Downloaded:  4334 Time(s)
Drone
PostPosted: Tue Mar 04, 2008 8:32 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hey Static Strobe Emitter, nice to see you back & thanks for sharing !
It is at least ten times more difficult to get a good synthesizer sound than on an acoustic instrument. - Giorgio Moroder
PostPosted: Tue Mar 04, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, these are great! Glad to see you still in action!
Housefly
PostPosted: Sat Apr 12, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i had one of those, well actually it was a sega master system 8 bit. i still have a thumb (the right one) that is disformed from playing too much...
luckily strobe didn't compose the tunes back then... or the thumb would've dropped off completely
Audio files: 243
PostPosted: Tue Apr 15, 2008 6:34 pm    Post subject: =o.... Reply with quote  Mark this post and the followings unread
This is not NES, but it is 8-bit, so i better fit it in here Wink
This tune is an Atari tune, soundchip: Pokey
Composed in RMT (Raster Music Tracker).
Strobe - Robophobia III.sap.mp3
Robophobia III
brutal massacre of the poor pokeychip.
 Filename:  Strobe - Robophobia III.sap.mp3
 Filesize:  2.3 MB
 Downloaded:  4179 Time(s)
Audio files: 243
PostPosted: Wed Jun 03, 2009 4:01 am    Post subject: The chips!
Subject description: =o....
lol hi 2 u
strobe-sint.mp3
Super Intelligence
Stroby/Rhytmic :P
Chip: Nintendo 2A03
 Filename:  strobe-sint.mp3
 Filesize:  2.88 MB
 Downloaded:  3679 Time(s)
Audio files: 243
PostPosted: Wed Jun 03, 2009 4:42 am    Post subject: oh noes
Subject description: :))))
More NES goodies!
strobe-superduperspaceship.mp3
Superduper Spaceship
Chip: Nintendo 2A03
Notice: first NES tune ever by me to use 3 DPCM bankswitching.
 Filename:  strobe-superduperspaceship.mp3
 Filesize:  3.63 MB
 Downloaded:  3615 Time(s)
Audio files: 308
PostPosted: Mon Jun 15, 2009 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice ones strobe!
Audio files: 243
PostPosted: Sun Jan 03, 2010 2:36 pm    Post subject: :OO
Subject description: hi there
This tune started out just as an experimental tune,
where i basically wanted to see how far i could push bankswitching
with the NSF tune compiler.
also taxing on my own sample switching skills,
since the streamed samples can only use 16kb per bank
(hardware design on the NES) it turned out
to be a nightmare to make it sound as seamless as possible.
But here it is Razz
Many thanks to JSR who made the custom compiler, and listening to my inquiries and made modifications i begged for.
Without him, this frankenstein tune wouldnt have been possible for me.
strobe-zib.mp3
ZIB
Experimental NES Tune, excessive bankswitching, No DPCM counter clicks.
Music: Strobe, Compiler: JSR
 Filename:  strobe-zib.mp3
 Filesize:  5.71 MB
 Downloaded:  3464 Time(s)
opg
PostPosted: Wed Jan 20, 2010 1:11 pm    Post subject: Re: :OO
But here it is Razz
Aww yeah, that kicked ass. NICE WORK!
One Player Game | OPG on SoundCloud
