loss1234
Posted: Mon May 12, 2008 8:08 am Post subject:
ways of messing with CV? |
i am trying to find ways of warping, twisting, and melting CV signals. lets say I have a CV signal that is coming out of an envelope, or an envelope follower? how could i mess with it?
I know about (but dont know how they work) and have built some simple portamento/lag circuits. I also know about grant richters cv twister.
but what are some other ones? are there any really crazy CV mangler's out there? this is an area that really appeals to me because potentially you could get sounds that have almost nothing to do with the original CV signal.
and any theory links would be great (about how lags work,etc)
thanks so much _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
fluxmonkey
Posted: Mon May 12, 2008 8:20 am Post subject:
i often use LFOs into ken stone's wave folder with good results. not sure if it'd be as good w/ non-periodic CVs like envelopes... but i'll try it tonite.
b |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Mon May 12, 2008 8:39 am Post subject:
Seconded, I just put some LFOs thru the CGS wave mult this weekend for the first time to very pleasing results.
I like to mix a bunch of LFOs together and then manually control the mix, gets you lots of variation. But it does thend to tie up your hands a bit. |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
deknow
Posted: Mon May 12, 2008 8:55 am Post subject:
| Quote: | | it does thend to tie up your hands a bit |
you are in new york...it's perfectly acceptable to get some unpaid interns for this kind of task...just make sure to put lab coats on them.
deknow |
loss1234
ericcoleridge
Posted: Mon May 12, 2008 10:58 am Post subject:
Loss,
You probably already know about this one, but I really like Fonik's layout for the "buchlaesque" CV Processor--it's an attenu/inverter, lag, and offset in one path. It gives you a lot of control over a CV or LFO. I find it very useful. |
jnuaury
Audio files: 9
Posted: Tue May 13, 2008 4:11 pm Post subject:
this sounds less exciting than wavewarping but running cv through a vca to automate its depth is fun
ken stones analog logic board is also nice for altering cv (and audio)
but the vca trick doesnt require any more solder or money im assuming
this is a little different than the question but an emu i have played with has inverters that if nothing was plugged into the input you could get a steady +5 or -5 volts out of them. this is useful for putting your other modules into ranges they normally wont reach |
Joined: Apr 03, 2004 Posts: 24513 Location: The Netherlands, Enschede
Posted: Tue May 13, 2008 4:46 pm Post subject:
Oh, and when you have a spare 12 dB LPF that can go really low, like say to 1/4 Hz or so with a controllable Q ... it makes for a cool lag processor with controllable overshoot. _________________ Jan
Posted: Tue May 13, 2008 4:52 pm Post subject:
| Quote: | | you are in new york...it's perfectly acceptable to get some unpaid interns for this kind of task...just make sure to put lab coats on them. |
I like that Deknow !!!!!!!
Bill |
Posted: Tue May 13, 2008 4:55 pm Post subject:
How about transforming CV's and LFO's with quantizers like a Blacet "Mini-Wave" module or some other wave table based type quantizer. ?
I usually mangle waveforms using those ...........
Bill |
andrewF
Posted: Tue May 13, 2008 11:43 pm Post subject:
Two of the best in my synth are the CGS CV Cluster
and Harry's morph lag (for which Ken sells the PCB)
The CV Cluster is especially nice as it takes two CV signals and outputs 10...or more! that are all related but different. This allows for some very interesting andd intriguing polyphonic patches.
The morph lag works very well for bending stepped outputs, results in smoother tone/timbre transitions...altogether more watery. i should have a look at it with my scope one day and try to work out what is going on. |
CJ Miller
Posted: Wed May 14, 2008 12:22 am Post subject:
Don't forget rectification. And nonlinear waveshaping with diodes, which can also be used in conjuction with filters, fixed or otherwise. Applying various logical, mathematic, etc functions to CVs. Comparators, VC switches. Sample and hold, ramp and hold, track and hold, etc.
As has been said though, basic mixing, splitting, range, scale, offset, inverting, attenuation - these are the basic essentials, and far too few systems have these covered. And yes, lots of VCAs can be handy for handling signal and CV amounts. |
