SDS3 Single Voice PCB Run
Page 6 of 10 [245 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
mono-poly
PostPosted: Tue Mar 31, 2009 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Great to see you back on it!
PostPosted: Tue Mar 31, 2009 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
yes. i am still interested in these boards.
Luka
PostPosted: Tue Mar 31, 2009 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
hell yeah
problemchild
melbourne australia
Sound
PostPosted: Tue Mar 31, 2009 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
bubblechamber, thanks very much for your work!!!!
bubblechamber
PostPosted: Tue Mar 31, 2009 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Oli wrote:
bubblechamber wrote:
...anyway, here's the layout...
By the way, what EDA suite are you using?
i'm using osmond on a mac. it seems a lot more straight forward than just about anything i've used plus the free version is good for up to 750 hole layouts... and since i do my faceplates in illustrator i can bring a PDF into osmond as a template and it makes doing PCBs for control boards ful of pcb mounted pots extremely easy.
i'll be posting a control panel that will work with either a frac or euro panel in a couple of days. it will connect to the SDS3 board via the headers.
thanks for hanging in there guys. this has my full attention again , hopefully that make s a difference.
d
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
Oli
PostPosted: Thu Apr 02, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh, probably why I didn't recognise it. I do very little with Macs these days. Intuitivity sure is an ongoing issue with EDA's.
...since i do my faceplates in illustrator i can bring a PDF into osmond as a template...
Can't you use a DXF for that? I thought it would be easier to work with. I used to work with a graphic designer in my last job. I would get him to do the user interface and front panel layout in Illustrator, and use a DXF format drawing for use in my CAD software (Autocad and Protel). I'm pretty sure that's how we did it (it's going back a bit now). I think PDF's are less convenient to work with in CAD.
...i'll be posting a control panel that will work with either a frac or euro panel in a couple of days. it will connect to the SDS3 board via the headers.
Cool, looking forward to it.
Hey, thank YOU for hanging in there!
Good good study, day day up!
stijn
PostPosted: Mon Apr 06, 2009 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
jawohl!!! the sds3 boards are coming!!!!
nice to hear you're back on it Very Happy Very Happy Very Happy
johans121
PostPosted: Mon Apr 06, 2009 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
FWIW, I'm still interested in 4
Don't feed me Indian, you WILL regret it!
-Jim
mono-poly
PostPosted: Tue Apr 07, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers
bubblechamber
PostPosted: Wed Apr 08, 2009 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi guys -i just got back from a much needed break and got WAY less work done on this than i'd planned, but i'll be getting on with V.2 this weekend. did manage to get well into the latest Iain Banks novel, so that's something.
BTW i'm seriously thinking about making this a 2 sided board which should shave quite a bit of room off the PCB cause it's kinda big for a eurorack design, about 115MM wide as a 1 sided PCB. i'll still be posting a 1 sided version if anyone wants to roll their own.
this could all change if a 2 sided version ends up sounding different. there are those like Ken MacBeth that swear single sided sounds better, we'll see.
david
bubblechamber
PostPosted: Sun Apr 19, 2009 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hey guys- just a quick update. my laptop died last weekend and apple is replacing the logic board. i'll be back in the saddle this week and i'll be doing a new prototype next weekend. good tomes with computers, cause of and solution to all of our problems.
david
Floppy
PostPosted: Sun Apr 19, 2009 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
i totally forgot this pcbs, did i pay for them yet ?
Sound
PostPosted: Sun Apr 19, 2009 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Not yet Floppy, Bubble is working in it.
huck
PostPosted: Wed Apr 22, 2009 7:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am in for 3 for sure
thanks for doing this
Johnniebee
PostPosted: Mon Apr 27, 2009 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please add me to the list. I'll definitely take 2.
Thank you for all the effort you are putting into this project.
All the best.
John
parasitk
PostPosted: Mon Apr 27, 2009 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in two as well!
modularkomplex
PostPosted: Sat May 30, 2009 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to get 4 pcbs, too.
mike
strategy
PostPosted: Mon Jun 01, 2009 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for one!
- Strategy
community-library.net/strategyhome.htm
LektroiD
PostPosted: Mon Jun 01, 2009 11:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I'm not too late, I'm in for 4
LektroiD
mono-poly
PostPosted: Mon Jun 01, 2009 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
How far are we from order?
diablojoy
PostPosted: Sat Jul 04, 2009 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
if not too late definitely in for 4 boards
mono-poly
PostPosted: Sat Jul 04, 2009 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
David,
Any updates?
diablojoy
PostPosted: Tue Jul 21, 2009 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
seems maybe bubblechambers laptop problem worse than he thought ?
an update/news would be good.
Oli
PostPosted: Tue Jul 21, 2009 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
It sure would be nice to add these to the rig.
Maybe if there is a difficulty with particular aspects, then others could help out? I would be happy enough to try to help with electronics issues.
scriptstyle
PostPosted: Tue Jul 21, 2009 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
i was in contact with David back in april i was trying to lend a helping hand with some printing and prototyping. i havnt heard anything, im getting anxious on this one myself.
