 Forum index » Instruments and Equipment » Nord stage
Panel A/B swichting a extern Soundmodul
Page 1 of 1 [3 Posts]
KurtMuellner
PostPosted: Fri Apr 10, 2009 2:06 pm    Post subject: Panel A/B swichting a extern Soundmodul
Subject description: Switching from Prog 7 to 9 with Panel A, Panel B does not work.
I want to switch my extern Midi-Soundmodul from Program 7 to 9 with Panel A, Panel B swichting,
But it does not work.
My Equipement:
- Clavia NordStage 76 (4.02 OS)
- Waldorf Micro Q
My configuration: ( Program 3:2, Panel A light on, Panel B light off)
- NS: Panel A: Extern send CH 3, Prog 7
- NS: Panel B: Extern send CH 3, Prog 9
Result:
- If I set to 3:2 then Micro Q load Prog 9 (but it should load Prog 7)
- If I swicht to Panel B, nothing happens.
Background info
The same behaviour is also with another Soundmodul (Yamaha Motif).
A Experiment: if I connect two soundmodul to NS with a different configuration (NS Panel A: ext. CH 3, Panel B: ext CH 4). Programm send correctly to both Soundmodul, but that is not what I want. I want switch only 1 Soundmodul from Prog 7 to 9.
Any Ideas??
- NordStage Classic 76 - Yamaha Motif Rack XS - Nord Lead 3 - Korg MicroX - Access Virus Ti2 Snow
gearaholic
PostPosted: Sat Apr 11, 2009 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
before making any midi cable connections....
set ext a to program change and set value to 0 or 1(lowest)
set waldorf program to 0 or 1 (lowest)
connect 1 midi cable from stage out to waldorf in
turn ext value on stage and watch the waldorf and the programs should change
if they change take notes on:when the waldorf displays 7 (progam)what does the stage display say?
repeat above procces for waldorf program 9
if this does not solve it let me know
KurtMuellner
PostPosted: Fri Jun 19, 2009 2:49 pm    Post subject: NordStage 76 supports Yamaha Motif Rack XS with Multi-Modus
Subject description: Firmware (4.12) supports program change within Multi-Modus
Hi there
I have already updated my NS 76 with Firmware 4.12. Now, You can do program changes within the Yamaha Motif Rack XS's Multi-Modus.
Do this (NS)
1 go to Extern menu and switch from global to program.
2. configure: MSB=63, LSB=68, Program 0..127
3. configure Panel A e.g. Midi-Channel 2, Panel B e.g. Midi-Channel 3. Panel A/B Midi channel must be different.
4. you have to do this for all panel and programs
Do that (Motif)
1 Switch to Multi-Mode
2 Create some sounds ( e.g. one or two with midi-channel receive 2 and some other with midi 3
3 That's all
Congratulations to the clavia's software team!
A dream comes true.
My next wish is:
Saving Transpose for each program differently, not global!
see ya
Kurt Muellner from Switzerland
