Some liquid flux would prevent those solder tails on the ICs, and make the whole SMT soldering experience a lot easier. Look out for a needle flux dispenser bottle too. I presume you're using solder paste too? (solder-wire is a nightmare on SMT).
Looking great though! I can't wait the production run _________________
i AM using solder-wire it is 0.5mm and works quite fine on the 1206 packages IMHO.
however, i believe you and will try additional flux on the ICs. i have dispenser already... _________________
With paste it leaves your hand free to steady the component with tweezers, rather than holding the wire / tweezers and soldering iron - which would be ok if you had 3 hands.. _________________
i use the point of a compass to positioning a smd component in place and to hold him in place when i solder it,i applie wire solder first on one side of the pad on the pcb ,it goes faster as soldering classic components..
and i just hold everything in place with tiny bits of blue tack
and solder everything with a normal iron and .71 mm solder wire
works fine I only pick up the iron twice for the entire board ,very fast. there are seemingly many ways to do the same thing
1.5 mm solder wick will also get rid of the those tails very quickly and make those IC's very neat , just leaving solder under the tags only.
fonik do you plan to make the surface mount boards available ?
1st i place a little bit of solder to one one pad for each component.
i then place and fix all components reheating the solder.
in a third run i solder the left pads.
it is indeed faster than TH.
i see more interest in SMD, however the majority still wants TH? i will start a poll... _________________
two squarewave oscillators are used. the carrier oscillator gets controlled by the sequencer. the sequencer also controlls the carriers input.
the modulator input gets controlled by a LFO.
i am playing with the settings of the VCMod, even some nice gate/VCa action is possible.
okay, i tried my best just for you. i mean, i am not that good in generating specific sounds on my modular... anyways, here an LFO controlled the modulating sine. the output goes to a envelope controlled ssm2044 filter (no resonance).
i will be on vacation soon. so the higher pitch bells will have to wait. the VC Clock and VC Mod TH ProtoPCBs are in. i think i will have built and tested them end of month. after that i will ask for interest. _________________
okay, last minute bells.
i don't have all my gear at one place currently, not to talk about set up for recording. so at the moment it is always a little bit complicated to record my modular, i have to move things around. will change this later this year...
I notice you've got expo current sources running the input VCAs. I'm assuming it sounds just fine, but have you also tried it with the "standard" linear VCAs?
Tim (non-linear) Servo
not yet. do you think it would geive me better control/response? when turning the knobs it felt/sounded quite right... _________________
Posted: Fri Jun 25, 2010 5:14 pm Post subject:
Voltage Controlled Ring Modulator Module (OpAmp based)
Makes sense. Controlling an expo VCA with a linear CV pot will give you a natural sounding exponential response. I don't know if it will still sound correct when controlled with an exponential envelope though. My guess is that it won't be a problem, but it's worth checking.
Tim (doesn't make sense, but that doesn't keep me from trying) Servo
