is this really a frequency shifter?
Page 1 of 1 [7 Posts]
jnuaury
Audio files: 9
PostPosted: Tue Nov 16, 2010 6:35 am    Post subject: is this really a frequency shifter?
Subject description: super simple lm1496 circuit
http://www.angelfire.com/music2/theanalogcottage/ssbmult.htm
pretty skeptical of this circuit... but looks like ill get some lm1496's in my next parts order to try it out anyways
az/gde
Flickr
YouTube
LektroiD
PostPosted: Thu Nov 18, 2010 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks interesting. I have some LM1496's in my stash too. I guess a redraw of the schematic is in order. If you get this finished, let us know what it sounds like (maybe an mp3 demo), and if possible your revised 1496 schematic would be quite handy too.
LektroiD
JAMESveeder
PostPosted: Thu Nov 18, 2010 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes I'd definitely like to see how this turns out, or read up on some more info about it
Audio files: 326
PostPosted: Thu Nov 18, 2010 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is a ring modulator of sorts .. but it is claimed to leave only one side band ... as such it would behave like a Bode frequency shifter .. I'm not sure how well it would suppress a sideband though ... it's a lot simpler than an actual Bode frequency shifter .. but then again ... a ring modulator does shift frequencies.
Just to be sure ... this is something different than a pitch shifter .. a pitch shifter will leave harmonic relations as they are, where a frequency shifter does not.
http://acapella.harmony-central.com/archive/forums.html/t-1030019.html has some info.
Dego
PostPosted: Thu Nov 18, 2010 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The paia 4710 Balanced modulator uses a mc1496. Its more than like ringmodulation then... But it is used as a VCA as well.
Audio files: 326
PostPosted: Thu Nov 18, 2010 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Used as a VCA, yes ... basically ring modulation and VCA is the same thing ... a multiplier .. amplitude modulation, AM. Only thing is that many analog VCAs can use positive modulation voltages only, making it a two quadrant multiplier ... whereas for ring modulation you need four quadrant multiplication (where the amplitude controlling CV can be negative too).
Another difference would be that a VCA usually is used to apply an envelope, that is low frequency modulation, whereas for ring modulation typically audio rate is used ... but nothing stops you to control a VCA at audio rates .. and some simple trigonometry will show the frequency shifting stuff happening then.
jnuaury
Audio files: 9
PostPosted: Sat Nov 20, 2010 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
so i just made a parts order a couple days ago and totally forgot to pick up those chips! oops.
im familiar with various ring mods that use this chip, but am really curious to see how this "frequency shifter" will react
im tempted to pull the chip out of my doepfer ringmod to test it out sooner
az/gde
Flickr
YouTube
