Joined: Apr 03, 2004 Posts: 24513 Location: The Netherlands, Enschede
Posted: Tue Jul 31, 2012 7:36 am Post subject:
Usually shorter, but can take longer too. _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 7:58 am Post subject:
| one thing, have you updated the firmware on the Konnekt48 at all? |
Posted: Tue Jul 31, 2012 8:47 am Post subject:
Think so, I got the latest version when I set up the Kyma stuff a couple of months ago. After that I did not touch it, and used the settings for it as recommended by Symbolic Sound (even when that means it's VU meters dont work anymore ). _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 9:31 am Post subject:
VU meters don't work, thats strange isn't it?
Well we are up to 10:30 here now with no problem.
I just looked back at my emails to see when I had the firewire problems and it was October 2009, after a few rounds of debug logs with Symbolic they seemed to sort it out.
What sort of mac are you using? |
Posted: Tue Jul 31, 2012 10:04 am Post subject:
macbook pro on osx 10.5.8
And them VU meters, well that seems to be part of the recommended settings, dunno ... _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 10:37 am Post subject:
I am testing on a MacPro on 10.8 so its not really like for like I suppose.
Coming up to 12 hours now, I will run it till I go to bed then I will have to turn it off as it is in the bedroom and i cannot stand the fan noise!
What is the longest you have had it going on the Konnekt48?
Andy |
Posted: Tue Jul 31, 2012 11:27 am Post subject:
on that sound .. maybe a day .. not sure. _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 11:54 am Post subject:
Ah, Ok. I thought it went quicker, so this test is not going to be up to much then!
I will leave it running overnight as well.... |
Posted: Tue Jul 31, 2012 1:38 pm Post subject:
Oh dear, I wouldn't want you to sleep on the couch tho  _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 2:09 pm Post subject:
Let's see how long I can take it!
One of the fans whistles in a very annoying manner. |
Posted: Tue Jul 31, 2012 2:42 pm Post subject:
I've started it here again too with that tc thingie .. 48 minutes now it sez _________________ Jan
BobTheDog
Posted: Tue Jul 31, 2012 10:01 pm Post subject:
Hi Jan,
Sorry I had to turn it off last night, I couldn't get to sleep. It managed 17 hours before I killed it.
At the weekend I am moving a load of stuff around ( decorating ), I will unrack the K48 and the pacarana and connect it to the laptop somewhere else and leave it running for longer.
Andy |
Posted: Wed Aug 01, 2012 11:23 am Post subject:
heh, quite understandable.
Meanwhile it stopped working here again, this time after 16:03:19 and this time it got stuck repeating one sound no message or nothing, it just stopped.
The pacarana is still responding to its front panel. Trying a DSP restart ... nothing .. trying again ... cursor is a bit nervous but nothing else happens .. quitting Kyma, it won't stop .. force quiting Kyma and starting it ... starting patch again .. it runs.
Every time it is a new surprise when it stops and how it stops
On the USB interface it will stop too, it just takes a bit longer usually.
This is so fokking frustrating and disappointing.
Anyway, sending in another debug log. _________________ Jan
BobTheDog
Posted: Wed Aug 01, 2012 11:33 am Post subject:
If you get FireWire errors using the USB interface it must be the connection between the pacarana and the laptop?
I take it you gave tried different leads?
Can you introduce the error by moving the lead around, I know that can throw mine. |
Posted: Wed Aug 01, 2012 1:27 pm Post subject:
Yes I've tried different wires ... but I do not just get firewire errors (as illustrated in my previous post where I did not get any error at all but just a hangup of Kyma (apparently, as I did not restart the pacarana this time but had to force quit Kyma), but also the pacarana can crash in such a way for instance that its front panel is not operative anymore and I need to pull the power plug from it).
Anyay, I've just set up the thing with the TC again, for which I tried different wires too.
And as the FW800 connectors are pretty lousy I even tied them up a bit so they won't wiggle out by them selves. _________________ Jan
Posted: Wed Aug 01, 2012 1:28 pm Post subject:
So there seems to be no such thing as "the error". _________________ Jan
BobTheDog
Posted: Wed Aug 01, 2012 2:36 pm Post subject:
Mmmmm.
I'll set mine up to run over the weekend and see how it goes.
Most people probably don't run them for a prolonged time. |
Posted: Wed Aug 01, 2012 5:12 pm Post subject:
Ran for 5 hours and a bit here now ... time for sleep .. will see tomorrow ... the debug dump i sent to symbolic sound indicated that the pacarana had been running for a minute and a bit when i made the dump .. but I did not restart it
Anyways, time to sleep a bit. _________________ Jan
Posted: Thu Aug 02, 2012 4:03 pm Post subject:
Pulled the audio i/f pulled the ethernet cable .. disabled wifi on the mac and stopped all needless apps there, then started the patch again on the silent device ... 3:28:00 now and still running ... _________________ Jan
BobTheDog
Posted: Sun Aug 05, 2012 8:19 am Post subject:
Hi Jan,
It is all set up and working....
Lets see how long it goes
Andy |
Posted: Sun Aug 05, 2012 9:03 am Post subject:
Has been running here now for 68 hours and a bit (with all stuff pulled as described above) ... starting to go somewhere ... but I've had it run for 70 hours before (with USB audio I/F) which is just not long enough for me ... anyway, I'll keep it running for a bit more. _________________ Jan
BobTheDog
Posted: Sun Aug 05, 2012 9:27 am Post subject:
So as long as you don't want any audio then it sounds like you are fine, I don't know what your complaining about  |
Posted: Sun Aug 05, 2012 9:36 am Post subject:
All nice and quiet now, yeah  _________________ Jan
Joined: Jan 31, 2003 Posts: 18262 Location: Durham, NC
Audio files: 229
Posted: Sun Aug 05, 2012 1:22 pm Post subject:
I haven't read all of this thread, but I think Blue Hell's music is in it's own space; music that takes much longer than a typical song, or even a symphony or CD. Noodles are designed to play forever, like the sound of the sea shore or Victoria Falls. That's a concept that most people don't really appreciate. So, it's not so strange that an instrument that stops playing after a few days is problematic. _________________ --Howard
my music and other stuff |
Posted: Sun Aug 05, 2012 2:01 pm Post subject:
Especially so as the system supports timing as slow as two years ;-) _________________ Jan
