Lfohead Spectrum Flattener (Inspired By Rob)
Page 1 of 1 [3 Posts]
Lfohead
Audio files: 6
G2 patch files: 28
PostPosted: Sat May 03, 2014 2:47 am    Post subject: Lfohead Spectrum Flattener (Inspired By Rob) Reply with quote  Mark this post and the followings unread
Saw Robs Spectrum Tilter once again and thought if tilting is possible i bet flattening would be possible also...
Lfohead Spectrum Flattener (Inspired by Rob).pch2
 Filename:  Lfohead Spectrum Flattener (Inspired by Rob).pch2
 Filesize:  1.57 KB
 Downloaded:  4214 Time(s)
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat May 03, 2014 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Lfohead !
I allready like and use the Robs Spectrum Tilter. Your patch is very interesting too.
The synth part is not from me but with your spectrum flattener patch, I love the result. Very nice sound for the size of the patch Very Happy I have to edit some patch of mine now !
EDIT : ok... after 2 hours playing with the "Lfohead Spectrum Flattener (Inspired By Rob)" patch, I'm addicted.
Acid_Lead-Lfohead Spectrum Flattener.pch2
This is just another exemple for the Lfohead Spectrum Flattener patch. The synth part is not from me.
 Filename:  Acid_Lead-Lfohead Spectrum Flattener.pch2
 Filesize:  2.08 KB
 Downloaded:  4268 Time(s)
G2 patch files: 38
PostPosted: Fri May 09, 2014 10:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey !
On the chat, you said the patch is optimized to 90%. What are the remaining 10% ? Is in on high or low frequencies ? Or on all the spectrum ? I can try to optimize it if you give me some ideas. I would like to learn a little more about this kind of patch. I think I understand 80% about the actual patch... Do you use a spectrum analyser ?
Smile
