Streaming now
Three PWM controlled Oscillators
Page 1 of 1 [5 Posts]
Steveg
PostPosted: Sat May 16, 2015 10:11 pm    Post subject:  Three PWM controlled Oscillators
Subject description: Obviously madness
I was having a read of synaesthesia's current controlled oscillators and I was thinking of other ways to achieve the result so I came up with the PWM controlled oscillator. You may ask what is the advantage of controlling the oscillator this way if you just need another oscillator to control it? Well one PWM oscillator can control a whole bank of different pitch oscillators. See PWM-1.
U1B is needed so that the output remains a square wave otherwise you get duty cycle control not frequency control as in PWM-2. The structure D1/D1/R1/U1B is an alternative OR gate that has a lower chip count if you are only building one or two oscillators. U1B could be any non-inverting gate which is needed to correctly provide a current sink.
You can also partially control the oscillator using something like PWM-3. The RV1A/R1/RV1B structure is intended to control the degree of modulation but I think it is wrong. I think I need to split R1 into two and connect the center to half the supply voltage. Using a second dual pot RV2A/B keeps the relative contributions of the two current sources proportional so they track nicely across the frequency range.
In all three cases the PWM frequency needs to be higher than the output frequency to get accurate control. If the two frequencies are close the you will get aliasing effects. With PWM-3 if the PWM source is a 50% duty square wave with a lower frequency than the output you will get frequency modulation of the output.
 Filesize:  15.3 KB
 Viewed:  438 Time(s)
 Filesize:  13.38 KB
 Viewed:  446 Time(s)
 Filesize:  12.7 KB
 Viewed:  412 Time(s)
Steveg
PostPosted: Sat May 16, 2015 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aargh! The preview shows the attachments in reverse order to how thew will actually be displayed! Confused
joshs
PostPosted: Sun May 17, 2015 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
So varying the duty cycle controls the frequency of the oscillators? Got any sound samples of this? Might be useful for use with atmega chips since they have PWM but not analog outs.
elektrouwe
PostPosted: Sun May 17, 2015 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Steve, that are nice variants of the pulse controlled oscillators/analog freq. dividers or whatever they are called. You could simplify the design by replacing the AND+XOR+INV by a simple analog switch (eg. 4066) or by a tri-state output gate ( eg. 74HC125 ). For a circuit with 1 master oscillator even a 74HC573 or an octal tri-state buffer could be used to control as much as 8 oscillators by 1 pwm source.
note: I've breadboarded this last year; I remember that I had to alter some R,C values to make it work in the bass audio range which I shamefully did not correct in the schematic...
 Filesize:  84.5 KB
 Viewed:  562 Time(s)
Steveg
PostPosted: Mon May 18, 2015 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooh! thanks for that electrouwe! I hadn't thought in terms of Analog switches or tri-state. Very Happy
I'll have to see if I can simplify the FM modulator to use 4066s.
@joshs - sorry I haven't actually built any of these yet.
