midisyncing problems
Page 1 of 1 [6 Posts]
laurentius
PostPosted: Fri Jan 26, 2007 1:41 pm    Post subject: midisyncing problems Reply with quote  Mark this post and the followings unread
hi there,
i am still pretty new in terms of programming the modular g2. i have a super basic problem with syncing sequences and stuff like that to midi. i am aware of of the button for master/intern.
my problem is how to make a sequence or drum pattern sync to midi but still retrigger (play from the one) whenever hitting the keyboard.
sorry to bother you with this trivial thing Wink
p.s.: once i found a great adaptation of sherman filterbank in here. do you think i still need to check out the original one or should the modular version (from this forum) be good enough. i am talking about dynamic range, sound quality, etc...
thanks,m
laurentius.
PostPosted: Fri Jan 26, 2007 2:55 pm    Post subject: Re: midisyncing problems Reply with quote  Mark this post and the followings unread
On any note or on a particular one ? Should it be manualy synced or should the keypress be auto synced to the clock ?
laurentius
PostPosted: Fri Jan 26, 2007 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
either way. in my case i have the following in mind: i hit a chord on the keyboard and want the sequence to play the pattern from the one on (eventhough the bar of my arrangement might be on the three,etc...)but the sixtenth steps should of course be still in time with the overall tempo.
actually another basic question: when i sync a sequence to the midiclock: when i stop the sequencer and relaunch it how do i make the sequence in my modular relaunch as well - her to be always perfectly in sync.
thanks alot for your effort.
PostPosted: Fri Jan 26, 2007 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure I got it, somethoing like this ?
As to the other question, maybe use the Active output of the clock module to reset the sequencer.
seq_kb_snc_01.pch2
 Filename:  seq_kb_snc_01.pch2
 Filesize:  1.97 KB
 Downloaded:  2679 Time(s)
laurentius
PostPosted: Fri Jan 26, 2007 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks man,
thats it!
PostPosted: Fri Jan 26, 2007 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
