Trouble coding a simple method call.
Page 1 of 1 [3 Posts]
sir honey
PostPosted: Sat Feb 03, 2007 9:20 pm    Post subject: Trouble coding a simple method call. Reply with quote  Mark this post and the followings unread
Hi All,
I'm very new to ChucK and looking to make progress and friends here on the forum. I'm confused about many things at this early stage of the game, but maybe somebody would be nice enough to help me with this one snag I can't seem to wrap my head around.
when I code:
SndBuf sam => dac;
"/mysample" => sam.read;
while (true){
Std.rand2f (0.0, sam.samples ) => sam.pos;
sam.play;
1=> sam.loop;
1::second => now;
I'm unable to compile the program. now, is this a syntax error that I'm encountering, or a misunderstanding about how the Std.rand2f should function? Forgive my ignorance, I'm pretty new to programming, and have much more of a music background. I would just like to play "mysample" from a different random point in time with each iteration of the loop.
Thanks. I think this forum is a great resource, and I'm glad to participate in this friendly community.
jack
spencer
PostPosted: Sun Feb 04, 2007 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey there, jack, welcome to ChucK!
There are a few problems I can see. Firstly, the .pos parameter expects an integer, not a float--thus you should use the Std.rand2 function (and change the floating-point 0.0 argument to just an integral 0). Secondly, functions that don't have arguments need an empty set of parentheses. Thus
Code:
sam.samples
should be
Code:
sam.samples()
and
Code:
sam.play
should be
Code:
sam.play()
Also, the sam.play() call is actually not necessary--the SndBuf will play of its own accord when you pass time with the 1::second => now;. sam.play() just returns the playback rate, and is functionally the same as sam.rate().
So all in all this revised version should work:
Code:
SndBuf sam => dac;
while (true){
Std.rand2 (0, sam.samples() ) => sam.pos;
1=> sam.loop;
1::second => now;
hope this helps,
spencer
sir honey
PostPosted: Sun Feb 04, 2007 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot, Spencer
That does help, and thanks for the welcome!
If I didn't have to work, I'd ChucK all day long.
best,
jack
