NL3 and MIDI/multitimbral
Page 1 of 1 [6 Posts]
drjoshua
PostPosted: Sat Mar 17, 2007 1:36 pm    Post subject: NL3 and MIDI/multitimbral
Subject description: When 4 part timbral´s not enough?
After what I understand you can get Cubase to play sounds from NL3. But what should I do when the 4 part timbral´s not enough?
If I have a sequence in Cubase with for example 8 sounds. Can I transmit 4 sound from my NL3 to my computer and play them like a softsynth?
Help a newbie out here!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 17, 2007 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't understand what you mean with: 'Play them like a softsynth'...
You can program 4 Midi data files in Cubase and record these sounds in the audio tracks. If you need more you do this again with new Midi data files and different sounds and record these on other audio tracks.
Wout
drjoshua
PostPosted: Sun Mar 18, 2007 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
But then, if you´re not satisfied with one sound, you can´t change that sound with no less than recording these four Midi files again, or?
In a 8 "chanel" Midi track, can you mix sounds from a NL3 and a soft synth in the same recording?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 18, 2007 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
First, Midi isn't the same as sound, just a protocol which 'tells' a musical instrument what to do.
Secondly, CuBase doesn't make the sound, just Midi and a recording device.
Third, if you save your Midi data, you can use it over and over again.
Fourth, your question is more about Midi then about a synthesizer.
Anyway, as long as your system can handle it, you can record as many tracks as you like, so at least 16 synths, software or hardware, are possible!
Maybe a book about Midi will enlight you more Smile
Wout
drjoshua
PostPosted: Sun Mar 18, 2007 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! You´re right. I have to do some homework before I go bother you here.
Be sure, I´ll be back with more questions.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Mar 18, 2007 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Always welcome Smile
Wout
