Trig the sequencer
Page 1 of 1 [6 Posts]
Tool
PostPosted: Thu Mar 22, 2007 7:50 am    Post subject: Trig the sequencer Reply with quote  Mark this post and the followings unread
Sorry for my english first...
I want to keep the sequence off and start it with pressing a key... but i dont know how... all the sequences I have found start automaticaly when you load the patch... but I want to start the sequence with the keyboard...
Thanks
slave to this
G2 patch files: 7
PostPosted: Thu Mar 22, 2007 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
you can add some features, but here's the most basic...
james
*edit---
sorry for the double file, they're both the same
keyseqstart.pch2
 Filename:  keyseqstart.pch2
 Filesize:  1.1 KB
 Downloaded:  1687 Time(s)
keyseqstart.pch2
 Filesize:  1.1 KB
 Downloaded:  1677 Time(s)
slave to this
G2 patch files: 7
PostPosted: Thu Mar 22, 2007 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's another that keeps the sequencer going even if you don't have a key held down (if that's what you were looking for to begin with).
keystartseq2.pch2
 Filename:  keystartseq2.pch2
 Filesize:  1.14 KB
 Downloaded:  1680 Time(s)
Tool
PostPosted: Fri Mar 23, 2007 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you! u can't imaging how much time i was trying this.
slave to this
G2 patch files: 7
PostPosted: Sat Mar 24, 2007 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
no problem! here to help.
Christophe Duquesne
G2 patch files: 6
PostPosted: Sun Mar 25, 2007 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Just another one I'm using
There are two seqs, you get the second one one playing the C3....
The Seq is not retrigered at the end, so you have to do it by repressing the key... it is usefull on stage when playing with some none computer musicians ....
If it can help ....
Actionnaires.prf2
A performance I'm using on stage with key trigered sequences ...
 Filename:  Actionnaires.prf2
 Filesize:  10.73 KB
 Downloaded:  1758 Time(s)
Christophe Duquesne
