 Forum index » Clavia Nord Modular » G2 Performances - Noodles
07-015-003
Page 1 of 1 [7 Posts]
Audio files: 297
PostPosted: Sun Apr 08, 2007 1:49 pm    Post subject: 07-015-003 Reply with quote  Mark this post and the followings unread
This one had a tendency to be a bit rough on the speakers. Slot A is doing it, I think I tamed it enough, but to be sure maybe don't play it too loud.
When on an unexpanded G2 the voice count for slot A is 1 maybe disable slot C (it just adds some rumble), or alternatively turn up the constant in the upper left of slot A to make it 'act' more often.
The crackle is intentional.
07-015-003.prf2
 Filename:  07-015-003.prf2
 Filesize:  9.48 KB
 Downloaded:  2518 Time(s)
Audio files: 297
PostPosted: Sun Apr 08, 2007 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a little blurp it made.
07-015-003.mp3
 Filename:  07-015-003.mp3
 Filesize:  2.42 MB
 Downloaded:  2298 Time(s)
astroid power-up!
PostPosted: Sun Apr 08, 2007 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
pretty:)
sounds like music for a movie about cells
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Audio files: 297
PostPosted: Mon Apr 09, 2007 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Scott.
I wonder ... do you mean cells as in "terrorist cells", or as in "prison cells" ?
Housefly
PostPosted: Tue Apr 10, 2007 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Scott.
didn't listen yet, but maybe he's talking about biological cells, you now, the ones your body is made off Wink
Audio files: 297
PostPosted: Tue Apr 10, 2007 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Housefly wrote:
Thank you Scott.
Right, didn't even think about that possibility, simple enough to be true I guess Very Happy
PostPosted: Fri Apr 20, 2007 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes - hypnotic. Primordial soup. I like the way it rests and then builds up.
/Stefan
