 Forum index » How-tos
I need Help!
Page 1 of 1 [5 Posts]
props
PostPosted: Mon Apr 23, 2007 1:20 pm    Post subject: I need Help!
Subject description: I have a novation x station and i want to get it to work with Audacity or a similar program
Im new to the forum so hope you will all be helpfull
thanks
Jason
PostPosted: Mon Apr 23, 2007 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to the forum.
Its best if you give as much information about what exactly you are trying to do.
Audacity is a very limited free application not capable of recording midi. However once your X-Station is properly setup and installed you should be able to record using the usb audio alone in most any software that could support it. The X-Station has software drivers that are available which should be installed. Once that is done you would need to select the proper input within Audacity's preferences/settings etc. This would allow you to record the audio from the X-Station.
Again this is a very limited software option but it's great that its for free.
There are a variety of very inexpensive "light" software options which I would also recommend from most all good audio software companies like Steinberg and even Cakewalk.
Jason
PostPosted: Mon Apr 23, 2007 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also its best to post your post in the body of the message instead of the subject to be clear please. It makes things a little easier I think.
Thank You Surprised
props
PostPosted: Tue Apr 24, 2007 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
see i have a disc with software but its giving me nothing but hassle ive loaded up two things off it and neither is the BIG program if ya get me!
Jason
PostPosted: Tue Apr 24, 2007 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just download them directly using this link
http://www.novationmusic.com/product.asp?id=1&view=downloads&Type=1&bArchive=False
They will probably be more up to date than what you have on your disc.
Also most likely on your disc is demo or light software better than Audacity... ... ... ... .... Rolling Eyes Rolling Eyes Rolling Eyes
