 Forum index » DIY Hardware and Software » Supercollider
Latoocarfian on both channels
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [9 Posts]
alistair
PostPosted: Sun Oct 07, 2007 2:49 pm    Post subject: Latoocarfian on both channels
Subject description: left channel sounds way too strong
Hallo,
I have a really elementary question, I've been varying the Latoocarfian patch but on getting it to work on both channels...:
{ [ LatoocarfianL.ar(
SampleRate.ir/3,
LFNoise2.kr(10,1,1.5),
LFNoise2.kr(3,0.5,1.5),
LFNoise2.kr(7,1.5,1.5),
LFNoise2.kr(3,1.5,1.5)
), LatoocarfianL.ar(
SampleRate.ir/2,
) * 0.2 ]
}.play;
... ends up sounding like 2 independent Latoocarfians, only the left channel sounds very strong, and the level on the right channel is way too soft. Does anybody have any solutions as to how I can get both channels to play at the same level?
cheers in advance!!
dewdrop_world
PostPosted: Mon Oct 08, 2007 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've transposed the array end and the multiplication.
You have [a, b*0.2] so if a and b have the same initial level, then yes, the right channel will be softer.
I think you meant [a, b] * 0.2?
James
alistair
PostPosted: Mon Oct 08, 2007 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers thanks a lot d_w james, I'll give that one a try, & tell you how I get on Wink
alistair
PostPosted: Mon Oct 08, 2007 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot, it was the exact answer: equal sound coming from both speakers! Smile
now, the thing that worries me is that the answer appeared fairy simple Rolling Eyes ... and I just didn't get it ! Maybe this is just how it always is Confused
Audio files: 308
PostPosted: Tue Oct 09, 2007 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
alistair wrote:
... and I just didn't get it ! Maybe this is just how it always is :?
When you indent your code it will be easier to see, like in
Code:
      LatoocarfianL.ar
        SampleRate.ir/3,
      LatoocarfianL.ar
        SampleRate.ir/2,
      ) * 0.2
  }.play;
Kassen
PostPosted: Tue Oct 09, 2007 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
It might've been indented. I think the board will eat spaces and tabs at the start of lines if you don't use the "code" tag. This gets annoying so in case of doubt use the tag.
Kassen
Audio files: 308
PostPosted: Tue Oct 09, 2007 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's true, if so I'm sorry for stating the obvious.
alistair
PostPosted: Fri Oct 19, 2007 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
No, for me, you're not stating the blindingly obvious, thanks to BH's advice I started indenting.... which certainly makes things easier.
Thanks BH ! Smile
Audio files: 308
PostPosted: Fri Oct 19, 2007 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
alistair wrote:
Thanks BH ! Smile
You're welcome Very Happy
